Old 04-26-2020, 02:07 PM
Like every other, I want to thank you for sharing all these process-details. That is extremely interessant!
Old 04-26-2020, 06:41 PM
SATAUS SATAUS is offline
Originally Posted by cliffrod View Post
Very impressive work, Scott. Thanks for posting such a thorough tutorial.
Thanks cliffrod
Scott
Old 04-26-2020, 06:48 PM
Originally Posted by Marc Bourget View Post
Thinking on the section below the window that you raised, are your vertical lines parallel, or do they taper in at the top?
Just thinking if I were to duplicate your task, would a taper make up for the loss of material from the cutting process ????
Hi Marc
Yes the lines taper, were ever possible I put my cut lines on an angle this gives me zero gap and then I can fusion weld the panel together.
Scott
Old 04-26-2020, 06:51 PM
No worries Antoine
Just trying to give back and I hope you can take something new from it
Scott
Old 04-29-2020, 06:41 AM
Default fire wall build
Scott
Old 04-29-2020, 07:13 AM
Default engine/chassis tube
Scott
Old 04-29-2020, 11:03 AM
MP&C's Avatar
MP&C MP&C is offline
Beautiful work Scott!
Old 04-29-2020, 11:29 AM
Hi Scott
Very nicely done!
Thanks for sharing a great series of pictures. A picture is worth a thousand words. Pictures speak all languages.
One question, was the cross member design required for packaging?
The detail pictures are great, but a couple shots from farther back might help some of us get a big picture perspective of the engine to vehicle arrangement.
Thanks for sharing
Old 04-30-2020, 05:11 AM
Very nice work. Very unique panel clamps too.
Old 04-30-2020, 07:15 AM
Hi Scott
Very nicely done!
Thanks for sharing
Sorry Steve when you work on something for so long you start to think every one else know what is going on with the project
I put the bend in the cross tube with the intention of routing the exhaust under the sump to the passengers side of the car (right hand drive) and down through the chassis K members. I was going to do this because a lack of room on the drivers side due to steering shafts, starter motor, brake booster etc.
Now I have the cab on the chassis I have worked out there is a lot of room between the outside face of the chassis rail and the inside edge of the cab so I will probably run the exhaust through there.
My plan is to have nothing hanging lower than the chassis rails.
I hope that makes thing a bit clearer.
Scott
