Old 03-14-2020, 12:34 PM
Craig510 Craig510 is offline
Default Wheeling Machines: Lazze vs Tommasini
I am in the market for a quality English wheel. I took the Lazze Metal Shaping class in February so I know his machines are high quality and do the job well. I was all set to buy one and then I discovered the Peter Tommasini cast iron ones.
Does anyone have first hand experience using both machines? It looks like you can get a smoother panel finish with the full radius wheels that Hoosier makes for the Tommasini wheel, however, I could order some full radius wheels for Lazze's wheel and the Lazze wheel comes with some offset wheels which were really nice for tight areas. Alternatively, I could order a couple of offset wheels and maybe one with some contact flats for the Tommasini one as well so the it is about a wash. I am just down the street from Lazze so I can pick it up in person. Price wise they are about a wash. I know I could build one for less (I am a Mechanical Engineer and would do way to much stress analysis on it) but I want to start making panels and not designing and building equipment right now.
I am a bit concerned with the inner frame clearance below the anvils on Tommasini wheel, it looks like you could run into the frame occasionally while making something like a motorcycle fender. His machine will also require fabricating a stand and making a foot adjuster for anvil pressure and ordering from multiple places plus international and domestic shipping. The Lazze machine is ready to go and the lower anvil is raised well above the frame for good clearance.
Notice how close the fender is to the frame?
Certainly a beautiful machine that will hold its value well and last 100+ years with proper care
Lazze's machine is form following function. Simple, efficient and rigid. This machine will last many years as well but closed box sections can rust from the inside out and due to all the Chinese and Euro knockoffs it probably won't hold its value quite as well.
-Craig
Old 03-14-2020, 01:14 PM
Chris_Hamilton Chris_Hamilton is online now
http://www.allmetalshaping.com/showt...eeling+machine
http://www.allmetalshaping.com/searc...=5266890&pp=25
Old 03-14-2020, 04:38 PM
I have a McPherson wheel, which is what Peter uses and looks like a bigger version of the Tommasini wheel. I have had no trouble using it, despite having instruction from DVD's rather than a person.
I have a set of full radius wheels and creating a curve from a flat sheet is fast and easy. I can't understand why anyone would want flats on their wheels; the idea is to stretch metal, not to crush a large area. Have a look at this;
https://www.youtube.com/watch?v=MbFa7KyZ_pA
Peter says that the McPherson is the best wheel he has ever used and he has used most of them.
Have you tried using the Tommasini wheel? I would, before buying a fabricated one.
Cheers Charlie
Old 03-14-2020, 05:55 PM
If you use a bevel wheel, the frame doesn't matter.
Old 03-14-2020, 08:24 PM
Attachment 55548
Attachment 55549
Very interesting. That would create a speed differential between the inner and outer edges of the upper wheel.
I think this is enough to put down a deposit on the Tommasini wheel of he is going to cast more.
-Craig
Old 03-15-2020, 02:20 AM
Craig. I wouldn't look for much science in the difference in peripheral speed and diameter. When shaping, you have to understand the fibers of the material and turn on your own mental cnc system.
Just a idea how to bypass the small limiting frame. Strength is important. A hard frame is important. You don't have to think about EW and its flexibility. You can only concentrate on work.
Old 03-15-2020, 09:11 AM
Keep your eyes peeled. There is a 'rumor' that another shipment of Peters wheeling machines might be being prepared for shipment to the US. Nothing concrete, but It is being discussed.
As a side note, the ongoing discussion regarding cast vs fabricated wheeling machines has generally been about design driven by ego, when it is actually about physics and technic as applied to the type of material being shaped.
A skilled metal shaper who understands this can make beautiful work regardless of machine style. Right left coast?
Old 03-16-2020, 01:26 AM
I think they're both great machines produced by knowledgeable experts wheeling out fantastic products on both. It just boils down to personal preference... and that's OK!
I have a self-fabricated clone of the Imperial machine, and guess what, it also works mighty fine too. Unless there is insufficient rigidity (spring and slop) in the X,Y&Z planes, I think any machine will work just about as good as any other.
I see many of the craftsmen (Wray, Peter etc.) jumping around on different e-wheels in their videos, and I think they just setup each machine by feel and get on with the job, finding each machine's sweet spot to suit the task at hand.
Manny
