Old 01-15-2017, 03:42 PM
Metalshaperdan Metalshaperdan is offline
Default Shelby Cobra, My first digital buck design.
Hi guys.
So I have set myself a large undertaking and I don't mean coachbuilding a cobra from scratch. No, my challenge ahead is to create a 3d digital buck when I am a complete novice at CAD and CAM software.
But the good news is a have one of the Shelby Cobra's made in Mexico sitting in my shop for the next 4 months and I have a the start of a digital buck given to me by a friend who has no interest is selling his design and was happy to see his design go to use.
So let me show you what I have so far.
Dan
Old 01-15-2017, 04:14 PM
Default Help needed
So what I'm thinking is, the best place to start is to double check the digital buck dimensions against the real car and make any modifications necessary.
But already my lack of 3D Cad has me at a standstill. The files supplied to me are a .igs and a .3DM and Fusion 360 works with .STL files I believe. Fusion will open an .igs file and all the stations of the buck are selectable with the mouse and are individual sketches but are not editable. So being that I want to edit the buck, I export the file as a .stl file. What I discovered and I'm sure is common knowledge to anyone but me (a total novice) is that a .stl file makes all the stations of the buck one solid mesh model made of triangles.
If anyone is willing to give me some guidance I'd more than happy to share the buck design and my findings. I know there is power in the minds of many at I'm out of my depth here.
Thanks
Dan
Dan
Old 01-15-2017, 06:35 PM
Dan,
I'd be glad to help with this. My experience with importing igs files is that you end up recreating the file by measuring and remodeling if you want fully editable. If you would like help with this, I would be more than happy to help and create a fusion 360 project that can be shared however you like. I also have the option of doing it in solid works if preferred.
Let me know if you'd like me to help.
Thanks,
Zeke
Ezekiel
Old 01-15-2017, 06:50 PM
I am also interested in any info that involves importing .iges files into SolidWorks. To date, I am importing the .iges file into SolidWorks, saving it as a .prt file and modifying it that file. then I export each piece as a parasolid. It has taken me a lot of time to do it this way, but I have been having satisfactory results.
Old 01-15-2017, 07:54 PM
Originally Posted by zekeymonkey View Post
Dan,
Thanks,
Zeke
Hi Zeke, that would be excellent seeing as Fusion 360 is cloud based. I don't have solid works so if you're ok with it, working from within Fusion 360 would be perfect. I'll look up on youtube how to share a project through fusion 360. Feel free to pass on any detail I may need to link up. Thanks.
Dan
Old 01-15-2017, 07:55 PM
I'm happy to pass on my knowledge as I figure this out!
Dan
Dan
Old 01-15-2017, 08:03 PM
Default The Shelby Cobra
Here are a couple pictures from of the original I have in my shop. I have heard these are not perfect but I'm hoping with the 3D model to correct and unevenness as I go.
Dan
Dan
Old 01-15-2017, 08:15 PM
Default Analog Scanner Phonograph 1:1
So I made this tool to copy the profile of the Cobra and make any edits to the 3D model when needed.
link to a 30 second video of me showing how it works.
https://www.instagram.com/p/BKwkE4kj...ation.tv&hl=en
It's sort of a bridge design but I think it's a more efficient design than a bridge. It makes a 1:1 stencil right at the point of tracing the profile.
This is just version one. I found the top slide would lag behind the bottom slide when going side to side and would cause a jarring in the movement. Not much but enough to make me want to improve on the design.
My next move is to look into V-groove linear rail extrusion and carts used for CNC machines. the system looks more ridged and so I'm thinking I should be able to delete the top rail and just use a bottom rail.
Dan
Old 01-15-2017, 08:25 PM
Dan
I've PM'd you my contact information.
Ezekiel
Old 01-18-2017, 05:58 PM
Your profile tracer has me thinking about how to create a buck 3d model using it. I think having the traced profiles scanned could be very useful. I would place a scale and a horizontal line on the drawings before scanning to help with scaling. The scans could then be used in fusion to create relatively accurate models.
My biggest question would be, how do you accurately measure and position the tracer location along the length of the car?
Ezekiel
