Old 07-10-2014, 08:22 PM
foamcar foamcar is offline
Great thread. Thanks for the input.
Phil
Phil
Old 07-10-2014, 09:34 PM
Barry Barry is offline
May 2012
Great info here!
David, given the risks of overheating the torch, and the fact that many do use lightweight (hence smaller) torches what are your thoughts on cooling the torch?
Besides stopping and waiting (and interrupting a long run which probably isn't ideal), would faster cooling - like dunking the torch in a bucket of water - be a viable practice?
Old 07-11-2014, 01:02 AM
Barry I have nothing against lightweight torches this is a different thing to a jewellers torch. I can't see the sense in using a jewellers torch, especially if it needs specially modified tips to make it work with sheet metal. As far as I can ascertain the equivalent to the number five tip I use for welding 1.5mm aluminium for a meco midget torch is a number 7 tip. This is the largest tip listed. It's never a good idea to use anything flat out at full capacity in my experience.
The reflected heat from welding with a large tip will tend to make the torch hot. I never have to cool my tips. I have done it on the lightweight tips. You can dunk the tip in water with the oxygen turned on slightly.
I will put more information in my thread on gas welding equipment soon but there is a difference between being comfortable when welding and using the tiniest torch you can find.
I do not sell torches or any tools for that matter so I don't have a vested interest in any particular type of torch. My intention is only to help people make informed decisions.
Old 07-11-2014, 02:28 AM
May 2012
Thanks for the clarification David
Old 07-11-2014, 06:25 AM
David, just as a reference, I am using a #2 tip on my Mecco torch for .060" aluminum and my 'comfort' level in its use is guided somewhat by the fact that in my racing career, I have dislocated my right shoulder, torn ligaments near my wrist, broken two fingers and had to have my palm cut from a hot racing tire after it got melted to it. I just don't like the longer torches, as they are difficult for me to both hold and control. I have found that the Mecco meets my own needs, and I currently know of no one that has been injured by it's use.
Thank you for your input on these matters.
Old 07-11-2014, 08:06 AM
robtg robtg is offline
A #7 tip,should weld .250" aluminum.
Old 07-11-2014, 12:54 PM
I guess it would, although I always using a cutting torch for that since it has enough heat and a big fat old flame.
