  #61
Old 11-19-2016, 04:19 AM
I use a skateboard wheel the same way for little over stretches. Gives a bit better grip to help contain the metal.
Old 11-19-2016, 07:32 AM
MetalShaper of the Month July 2017, Sept 2022
Good idea, I'll try that
Jeff
Old 11-25-2016, 11:06 PM
Default how to be sure on welds
As I smooth and tweak the upper portion I can see my welds are cracking in some areas. What's the best thing to do? Keep rewelding as I see the cracks or finish up the smoothing and then make a final pass?
Jeff
Old 12-07-2016, 02:46 AM
Are you using mig or tig Jeff?
Most important thing is to have the shape and fitment exactly right before even tacking parts together. Then after tacking, make any corrections to changes caused from doing that. Then fully weld and don't grind all the way flush before hammering out any weld distortion.
This will keep hammering of the welded joint to a minimum.
Old 12-07-2016, 02:07 PM
Attachment 39549
I'm guessing that you used 4043 filler rod??
If so, that is why the cracks when working your welds. 4043 is filler for welding castings.
You should be using 1100 filler or 5356.
Old 12-07-2016, 02:19 PM
Base metal is 5052, filler is 5356.
Jeff
Old 12-07-2016, 07:58 PM
AllyBill AllyBill is offline
Attachment 39549
You can pre-heat the job with a propane torch then spend a few extra seconds on each weld to allow a good heat-soak into the surrounding material. It's the local contraction that pulls your weld apart. If everything is preheated and already expanded the contraction is less localised but most important is to come off the heat slowly enough that the tack hardens under the flame and elongates naturally without cracking. Better still, if you can get on the back of the tack stretch it with hammer and dolly before it cools.
Been there, done that, thirty years of fabricating aluminium and I still learn something new every day.
Here to learn.
William Pointer
Old 12-07-2016, 08:33 PM
It's not cracking apart until I start to work it on the e wheel or hammer and dolly.
Jeff
Old 12-08-2016, 04:23 PM
Are you letting the tacks harden under the flame? Are you using gas or TIG?
Here to learn.
William Pointer
Old 12-08-2016, 06:10 PM
I'm using TIG
Jeff
