Old 02-21-2018, 01:33 PM
Default What type tool you have for bending 90 degrees ?
What type tool you have for bending 90 degrees 10 - 15mm bend height on the shape piece. Edge position for wire and the like. For pullmax or Eckold. I want to build an edge and do not want to use a bead roller.
Please give me advice, I do not want to invent it anymore.
Old 02-21-2018, 02:55 PM
longyard longyard is offline
A picture or drawing might help us understand Jaroslav.
Bill Longyard
Winston-Salem, NC
Old 02-21-2018, 04:11 PM
Default 90 degrres
Bill. I want to put the hem 90 degrees. In any shape - sheet cutout. I want a universal tool for Eckold or Pullmax or some home product.
I have a bead roller, but I want it another way.
I have a picture of the situation when I used a manual method for wire laying. I hope you used it in your book .....
http://allmetalshaping.com/showthread.php?t=16494
Old 02-24-2018, 01:32 PM
DSC031561.jpgBill, I have this foto. Only for first step and degree 90.
Old 02-24-2018, 02:58 PM
Originally Posted by Jaroslav View Post
Attachment 45673Bill, I have this foto. Only for first step and degree 90.
Pullmax makes a flange tool but is a dedicated flange height. With your machining skills you could do the corrections and have a few tools marked with the height you are looking for. Bill Longyard you should show a picture of what we discussed the other day
Dan Pate
Old 02-25-2018, 03:29 AM
Default Kind of tool.
Okay, Dan, you can give a photo of that tool. I can produce, but I do not have the idea what kind. When I do not know, I'll ask. As far as I know, I give advise. Eckold has a stroke of 8mm. Thank you for your advice.
I have beautiful machines and a lot of equipment and this (THIS) I'm doing a mallet (MALLET) or hammer. I'm sad because I do not know how diferently way.
Old 02-25-2018, 06:50 AM
I once thought about adding a second step to the Pullmax flange die to
make the wire pocket and then close it.
I never pursued it any further.
Ron
Ron
Old 02-25-2018, 08:19 AM
Ron you have me thinking wow
Old 02-25-2018, 09:47 AM
Was it trumpf that used a toggle lever in their flange tool? i think that would work for any flange height with a suitable back guide. cant find a picture of it but the lower tool was basically a flat anvil and the upper reciprocating tool had a L shaped toggle lever, the long part of the "l" contacted and trapped the work whilst the short part turned the flange.
Paul
Old 02-25-2018, 12:12 PM
http://www.smv.se/4daction/web_showp...01820/Flanging
Paul
