Old 01-06-2020, 02:11 AM
Brzeczyszczykiewicz Brzeczyszczykiewicz is offline
I always put on gloves for work. I have no heated workshop. The temperature as outside. Rust does not attack intensively.
In the morning I was convinced that this was the only solution.
Witold
https://photos.app.goo.gl/VTz6ETWQhnKyqUQYA
https://www.youtube.com/watch?v=hzcKlFjOAoE
http://forum.poziome.pl/index.php?topic=1989.0
Old 01-06-2020, 08:14 AM
Default rust
I love Cortec products for corrosion protection. No mess, no clean up. The only problem is when I forget to use them.
https://www.theruststore.com/Learn-about-VCI-W23.aspx
Bill Funk
Old 01-08-2020, 02:32 PM
geelhoed geelhoed is offline
Meet Hosts
Gibbs brand penetrant all around the shop. I try to keep a coat on all tools. Heat in shop helps a lot .Extra fans in the spring thaw.
Andy
Old 01-22-2020, 10:36 AM
smottin smottin is offline
Default Phosphate
I make my own phosphate solution for steel and iron tools.
I use 88%W/W orthophosphoric acid mixed in the ratio 15% into tap water with a sprinkle of sodium nitrate in it.
Works well to protect tools I them dip them in oil and hang them up gives a dry film similar to when they were first produced.
Lasts for ages this is well tested - I live in Wales!
Colin
