#61
I welded up the extension and will finish the support bracket tomorrow. I'm not going to trim and shape the opening in front until I have the fender modified and fitted up.
#62
![]() Quote:
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 09-15-2015 at 09:55 PM. |
#63
I finished off the extension support bracket and welded that in today. I'm almost done on the left side. I just need to close up that little window at the bottom of the cowl and it's on to the other side.
#64
![]() Quote:
Greg Last edited by Newstalgia1; 09-21-2015 at 07:07 PM. |
#65
I finally finished up the left side and welded up the repair in the floor.
#66
Moving on to the right rocker, the area by the rear fender is in a little worse shape than the other side was so I am replacing more of the quarter panel. First I cut up some 18 ga and I wheeled the panel a little to get a tiny bit of crown, then I tipped the flange that goes inward toward the inner quarter. I used the stretcher to stretch the flange which started giving me the vertical contour to match the body. It's very close to the right shape right now. I'll start smoothing it out and getting an exact fit next.
#67
I need some help figuring out a door skin method. If any of you have made door skins and can offer some advice, I'd really appreciate the input.
Please check the Advanced Questions section and see the thread "Making a Door Skin, Need Advice" I'll try to add a direct link here. http://www.allmetalshaping.com/showthread.php?t=14183
Jack Set a Goal So Big That You Can't Achieve It Until You Grow Into The Person That Can. Last edited by Jack 1957; 09-19-2015 at 11:24 PM. |
#68
I had a little time this morning to rough in the rest of the inner quarter. Looks OK and fits well. I can't trim it up until the rocker panel is installed.
#69
very nice work!!
merc |
#70
The outer rocker and rusted area of the quarter on the right side are removed and the inner is the same as the left side. Some surface rust but still solid and strong. floor braces are in good shape too so I'll keep them and coat them with Chassis Saver.
