Old 05-30-2018, 01:23 PM
keith keith is offline
MetalShaper of the Month November 2021
Default 1930 Model A Roadster Pickup Banger Build
What started out as a fun little pick up to run at the Dirt Drags and the Hot Rod Hill Climb turned out to be a little bit more work than originally thought. The hope was to de-fender it and put in a different motor and clean up the body. A older restoration from the early 70's and just a little refresh turned out to be just a little bit more.
From what I was told there were only 2400 roadster pickups built in 1930. After digging into it. It was decided it would need a little more than a refresh.
The original parts were removed in case it would ever be put back original.
A donor motor with a 32 police head , 39 trans with a Ansen adapter plate,a dropped front axle, a donor rear end and the original mechanical brakes make up the drive train. It would also require the worn look.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:26 PM
The frame was boxed and lightning holes were added and then shot SPI Black Epoxy.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:28 PM
The running gear going together.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:33 PM
The donor bed came from Colorado. It was rust free, but not dent free.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:45 PM
I love roadster pickups!
Old 05-30-2018, 01:51 PM
After looking at the original bed it was decided to make the bead to be the same on the back as the front.
The back is longer than the front. A little over 8" was cut out of the bed sides. A repop tailgate and front panel were bought for it.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:54 PM
Work then moved to the rust in the lower cowls.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 01:57 PM
Then onto the doors. Small pin holes on both doors.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 02:06 PM
The lower rear body panel had been repaired with fiberglass.
A new one would be made.
Keith Daleen
Sedalia,Mo.
Old 05-30-2018, 02:08 PM
It was decided to chop the windshield 3". didn't want to destroy the original windshield post so some new ones were made from scratch.
Keith Daleen
Sedalia,Mo.
