Old 05-15-2018, 03:03 PM
bimmer1980 bimmer1980 is offline
Thanks for sharing the shop and the projects!
I'm very interested in seeing more of your projects. Fascinating stuff!
I'm planning to head to WW2 days in Reading, PA on June 2nd and I usually try to get a ride in one of the WW2 planes... So far, I flown in the B-29, and Bucket of Bolts. At other places, I've flown on the B-17 and the Ford Tri-Motor.
Brad
Currently working on a new garage for the tools...
Also a member on garagejournal.com
Old 05-15-2018, 09:29 PM
Hi,
Enjoy your time at the Reading airshow, I have several friends that attend.
B
Bill Tromblay
Old 05-16-2018, 07:32 PM
fred26t fred26t is offline
Default Bill, any tips for realigning the 4 way box blades....
My 4 way came with newsprint shimmed blades on the brake. I also found the brake fingers to be a little to sharp (cut right through 3003) so I sanded the tip a little. I have made my own blades with drill rod tiged to steel plate fingers for my most common bend sizes. Fred26T
Fred26T
Old 05-17-2018, 11:39 PM
Hi,
Not sure if you are asking a question on aligning a box blade, can you be more specific?
Thanks
Bill Tromblay
