Old 06-10-2018, 03:41 AM
G Day Charlie.
I definitely cant fold that close with mine, as it doesn't have the clamp capacity, even when using spaces under the clamp bar.
I will post a pic of mine to show the difference on Tuesday when I go back to work.
Thanks for the test demo, as it proves that my machine is not up to scratch of the new generation.
Cheers John
Old 06-10-2018, 07:52 PM
Originally Posted by Oldnek View Post
G Day Bill.
What is the narrowest you can fold on the Bailey, I also noticed that in the pic of the machine it appears to have 3 magnetic poles where as my only has 2, So they must of changed to 2 power coils, for better hold down clamping.
Would the Bailey be able to fold the size channel I mentioned in my previous post.
If so I may have to upgrade, and sell Dave my one.
Regards John
Hi,
I think you could clamp on 1/8" of material and bend it. All depends on its length and thinckness.
B
Bill Tromblay
Old 06-11-2018, 03:46 AM
ekdave1962's Avatar
thanks Guys for your post, i know John had one and had issues with small folds , what appealed was the small foot print and im running out of space in my shed , but not much good it they cant to the types of bends needed for our work, mY have to re think my options
Cheers David
Geelong victoria
Australia
Old 06-11-2018, 04:17 AM
ekdave1962's Avatar
maybe something like this would be better
https://www.machineryhouse.com.au/S262
Geelong victoria
Australia
Old 06-12-2018, 05:39 AM
Images of my Magna Bender.
Must be 1st generation.
I may have to update, if the new can bend that close now.
Thanks for the update.
Old 06-12-2018, 08:02 AM
Alan Bottomley Alan Bottomley is offline
Originally Posted by Marc Bourget View Post
An electro magnet will heat Al up if you tarry!
The Magnabend is a DC (direct current) magnet and therefore will not heat aluminiun via the eddy current effect.
It will of course heat the metal workpiece a little by direct thermal contact if the magnet itself is already hot.
Alan Bottomley
Old 06-12-2018, 08:18 AM
Attachment 47815
Attachment 47816
Attachment 47817
Hi John,
Thanks for the images of your Magnabend machine.
Yes, that is definitely a first generation model.
The later machines didn't really improve the minimum distance between reverse bends but they did employ a stronger (E-section) design, which pushed the maximum thickness capacity from 1.2mm to 1.6mm.
I recently posted some information on my website which showed how to get closer reverse bends. See here:
http://www.aaybee.com.au/Magnabend/M...erseBendsClose.
Alan Bottomley
Old 06-12-2018, 09:40 AM
Originally Posted by Charlie Myres View Post
G'day Oldnek,
I made this yesterday and I can do three of the bends on the magnabender and the fourth one by hand.
Material is 1.2mm steel and the machine never lets go, even on the narrow flange which is 15mm.
I have used Bill's tip of placing some off-cuts under the small clamp plates to make them grip better and once I used some heavy steel plate to assist the process, but that is never needed on the long clamps.
Attachment 47763
Cheers Charlie
Hi Charlie,
Thanks for your post and the picture is very informative.
You mention that you did 3 of the folds on your Magnabend and the 4th one by hand.
Since the profile is a tapered "top-hat" you could probably do all 4 bends on your Magnabend, although possibly the sides of the top-hat may have to have a little more taper:
Please see this section of my Magnabend website:
http://www.aaybee.com.au/Magnabend/M...TopHatProfiles
Alan Bottomley
Old 06-12-2018, 09:51 AM
G Day Dave.
Ive had my Magna Bender for 7 years, their a good machine but you cannot do the simplest of bends with her, common to what we require.
Like trying to fold a U channel with flanges, or even a simple angle fold of 10mm x 30mm, as the magnets will not hold the clamp bar tight enough to fold something so small. The depth of fold is limited to thickness of the fold bar at 15mm.
It's frustrating that you can't even do a simple cross break in a sheet as the magnet and bar will tend to flatten the first crease you do, it's OK on small thickness sheet .06mm but anything thicker you fade the break. I had to make a new BBQ fat drainer tray and had to chase the 1st break by hand as it flattened out. The other day I had to fold some seat mounts with captive nuts, again simple U channel 13mm flange x 20mm high x27mm wide x 400mm long. Had to use a friends Pan Brake.
Radius bends are a treat as well as using other type of tooling for tighter or wider folds.
My experience since owning this unit, shallow tight folds will break the hold down bar, or it will slide away. The only way I have found I can achieve this is to fold a flange on a large sheet then cut it down and repeat as necessary.
In a nutshell,
To do all the folds the machine demos for you does them well. But rarely we need to use all those type of folds.
Hi John,
Please refer to this section of my Magnabend website:
http://www.aaybee.com.au/Magnabend/M...#TopHatsSquare
And also this section:
http://www.aaybee.com.au/Magnabend/M...TopHatsTapered
Alan Bottomley
Old 06-12-2018, 05:27 PM
Originally Posted by Alan Bottomley View Post
Hi Charlie,
G'day Alan,
On my test-piece, the 4th bend opened out the angle of bend number 3; this was not desirable as the most important dimension of the rib I made, was the angle and altitude of the tapered piece. Hence the reason why I did the last bend by hand.
Maybe I should try your method on a full-size piece; the material is 1.2mm gal.
Cheers Charlie
PS I like your website thank you for sharing!
