Old 06-21-2017, 08:44 AM
Default I updated my arbor press to use 'Patman's' new offerings.
deleted this post
Old 06-21-2017, 10:17 AM
looks good will.
Old 06-21-2017, 11:55 AM
Here's some more squishing ideas:
https://www.riogrande.com/Product/Bo...ter-Kit/110509
Bonny Doon has been going awhile .... sometimes it takes awhile to develop a really functional mechanical gizmo....
Old 06-21-2017, 01:43 PM
Looks great, Will. I was happily surprised to see PatMan's kit set up with your smaller press. We had a great conversation about what an arbor press can do. Pretty deceptive. If you have or find a cheap arbor press, it's a no brainer. The throat depth is the primary factor determining the size of work can be accommodated.
I've been working with this process for a while now and like it a lot. For certain shapes, it's fantastic. It is slower than other powered methods but it is silent, totally self-contained and very kind to sore body parts. It isn't going to do everything, but it will do a lot while not creating or leaving a single tooth mark that needs to be filed or sanded off like the Lancaster-type shrinkers/stretchers. Very cool...
I've also been wondering how feasible it would be to convert one with an electric motor- especially after seeing Will's nicer shrinker and stretcher that he built- to cycle the ram. Pretty sure someone else will get to it before I ever do.....
Old 06-21-2017, 07:06 PM
Your very limited by the close distance between the vertical members of that kit. I think you’d have a really hard time making your money back with that, I just can’t see it as being all that useful. ~ John Buchtenkirch
Old 06-21-2017, 08:04 PM
bobadame bobadame is offline
Looks to me like it would be very handy for motorcycle tins.
Bob
Old 06-21-2017, 08:30 PM
deleted this post
Old 06-21-2017, 08:51 PM
use a plain arbor press for the bike fenders, tank parts to weld, etc and save a ton of money over the Bonny Doon. I think there's any number of quality machines available through AMS members/companies here that would be a much, much better investment...
I got into the arbor press stuff specifically to do bike parts. It's really easy to be too aggressive with it. A 2 or 3 ton press will often have a throat of 10"-12" and usually only cost up to $300 or lots cheaper if you look around. It doesn't take much effort to move the metal- the only reason to buy a bigger tonnage press is for the increase in throat depth. A little 1/2 ton press will easily shape alloy or crs panel. That's what I mean by how deceptive this process is.
Before I bought the Bonny Doon, I would get a regular shop press with much greater dimensional capacity (and maybe air over hydraulic and more... $1k-$2k will buy a LOT of used shop press) and make some tooling for it. Some are doing it with a regular shop press instead of an arbor press.
Another one of the lingering projects here- I've been watching for both another cheap arbor press (to cut up) and a shop press frame. i want to be able to replace the hydraulic Jack with an arbor press ram and actuating lever as a better approach than working the Jack. Turning the ram and lever sideways would probably make it even easier to use a foot pedal to run the ram and free up you hands.
Old 06-21-2017, 08:55 PM
"I think you’d have a really hard time making your money back with that"
I hope Patman will post the reason he went to this trouble to provide this particular offering. It's not about the money.
Will, i think that comment was directed at the Bonny Doon kit. It costs as much as one of Peter's HandBuilt English Wheels!!...... PatMan's kit isn't that expensive, is it?
Old 06-22-2017, 09:23 AM
deleted this post
