Old 10-06-2014, 06:14 PM
Time to start on my first cross member. I must have at least two originals for it to be registered as a 48 Willys under club registration rules, in case I go that way for a 90 days a year permit. For full road registration I still require at least one.
Looking a bit worse for wear with rust, twists, bends, dents, holes and buckles!
The old PTO hole was a bit big to just fill with weld so dropped in a washer of the same thickness as the frame.
The copper spoon also works well on edges that need to be repaired.
A lot faster and less heat this way.
Well 40 odd holes filled and a lot of tacks on some rust pitting that was first cleaned out with my die grinder.
Both ends were twisted 5 degrees in the same direction. Most likely the centre section, where the tow hitch was welded on, was bent up after dropping onto a rock ledge.
Just bolted on the old rear cross member from the other frame to lever down on the ends while the press holds the centre steady.
All the twist gone.
As you can see the ends taper up to the same height as the end of the frame rails. Problem is that I am running the rear of the frame 6.5" narrower to match the width of the frame under the Grand Cherokee and all the axle bracket positions. These trucks have a 6.5" wider rear axle than the front and I will be running the same width front and rear.
After cutting to the new length, the ends no longer match the ends of the frame rails. So a wedge was cut out and the flange bent up to match it.
I will box this member as will be used to support a towbar as well.
Old 10-06-2014, 07:25 PM
Thanks Dan and Dave. I was not sure to include the chassis part of the build on here being a metal shaping site. Thought I would just show some of the more interesting parts of it anyway to get a better idea of how it came together.
As long as the chassis work is part of an end-to-end project that includes major metal shaping, like this will, it is fine to include it. If you were just going to describe the chassis work, we'd probably have a talk.
Old 10-06-2014, 07:34 PM
Excellent Kerry. Thank you for guiding me on it.
First parts of the donor Grand Cherokee are getting used!
Getting everything ready that must be done before boxing the frame rails start.
This is the engine and lower front suspension cradle sitting under the frame rail for the first time to check angles. The area where it bolts in the front was 3 degrees out. The lower flange of the rail needed to be titled down at the back to sit flat on top of the cradle.
Rather than cut and bend the flange down, I bolted in a piece of heavy angle iron the same size as the area it sits on the cradle. Then supported the back end of the frame rail and then simply stood on the end of the cradle pushing it down. This bent the lower flange down giving a nice smooth transition.
I have cut out the original mounts from the Grand Cherokee so that every thing is mounted in the exact same manner as the engineers designed it. This is the mount for the front of the engine cradle.
The threaded boss has some movement to allow fine adjustment when it bolts together. The supporting plate has been cut wider than the flanges so it will protrude through a slot cut into the boxing plate when it goes over it. It will then fully welded and ground smooth. This way it is supported on both sides like it was originally.
These are the mounts for the transmission and transfercase cross member welded in. Interesting how the engineers have the actual attachment point higher up in the frame rail rather than directly on the bottom flange. I would think this would add greater torsional rigidity, so why not utilize it
The threaded nut plate has been clicked into place and the support plate again had been made wider than the flange by the thickness of the boxing plate. It will have a slot cut in it so the support plate can be welded to it.
Also cut out of the frame of the Grand Cherokee the mounts for the rear panhard rod, or track bar, which bolts into the frame. I left part of the original frame attached to the threaded boss and welded around the perimeter. The other two large holes you can see are for the shock absorber and sway bar mounts.
You can also see here extra threaded bosses welded in case I am able to mount the fuel tank in the same position as it was in the Grand Cherokee under the cab floor next to the driveshaft. Many thanks to Dr. Lee of South Dakota for getting under his Grand Cherokee and getting the measurement I needed for that. Hadn't recorded it initially as didn't think it would be possible, but now think there is a chance and better to have them in place as cant add them later once it all is boxed
These are the mounts for the rear sway bar. They pass right through the frame rail and will be supported on the other side as well once the boxing is complete.
Sway bar mount ready to have the boxing plate laid over it and then fully welded.
Old 10-07-2014, 02:43 AM
Hi Marcus
Nice build you have going on.
A metal shaping 'god' friend of mine (Mike Roberts - facebook Hammer Works) put me onto a metal protection fluid called Epiphos. It's a quick drying phosphoric etch transparent primer thing... For most bits I use a small domestic spray bottle, squirt bits lightly and then wipe smooth/off with a rag. It dries very quickly, lasts for months inside and can be welded through without issue. The guy that acid dipped and fine media blasted our racecar shell, sprays it inside and out immediately after blasting. It's better than the Henkel 'Keyphos' I previously used. http://www.chemetall.co.nz/product/epiphos
Old 10-07-2014, 07:39 PM
Originally Posted by skintkarter View Post
Hi Marcus
I will keep an eye out for that. The lanolin works as an anti spatter too and use it either in a spray can or squirt bottle. Sold under the INOX brand as well. Use the Lanotec brand as well and has no effects on paint after being wiped off with thinners etc.
You might remember how the stock frame looked before I started altering the bends nearly 12 months ago.
I ended up only moving the rear most bend on the original configuration forward so that the rails will run parallel now starting at the firewall rather than the the forward mounts of the rear leaf springs part way down under the bed.
This is the biggest part that will be added to the frame rails from the Grand Cherokee. This is the support bracket for the upper wishbone and the coilover. Technically the upper wishbone on these is what makes it a coilover rather than a strut. A strut also plays a roll in locating the hub where as a coilover does not, but often the term now a days is used for both.
The pressing here is for extra lateral strength and to clear the coilover. It needs to be recessed into the rail to centre the load more above the rail and reduce twisting leverage. When I made the new bends in the frame I took this into account.
I find it easier to weld the plate that will line the notch on the frame rail over the actual mount so all the angles are correct.
I first clamped the mount back into place on the rail and then clamped the new plate section to the back of it inside the rail so I knew everything was in the right position. Then tacked from the inside before removing the mount so it could be welded. You can also see compared to the rail in the background, how I have extended the wider section of the flange past the notched section. I have added as much as the notch is deep so no lateral strength has been lost.
Starting to fully weld the plate in.
It was also fully welded from the back.
The section that will end up behind the mount has been coated with weld through primer to protect against rust between the two layers.
All angles and the position is double checked against what I recorded before pulling apart the Grand Cherokee. I have even have it over the same bit of concrete to keep things as accurate as possible having recorded the measurements on both paper and photos.
Mount sits flush against the rail now.
I found that one of the rails was nearly 3mm-1/8" lower than the other side at the end of the rail. As I don't have an oxy, I just ran an extra weld bead on the inside of the bend and then cooled the weld with the air gun to help it shrink. This caused the bend to tighten and lift the end of the rail level with the other one.
With the rails were perfectly level to each other, I could then level the two mounts against each other. I went off the upper wishbone mounting holes on both sides as their angles and height are the most important.
Welded in.
Started on making the templates for the boxing plate. To make the swaybar bush hole I just hit the top of it until it broke through.
Trimmed the outsides with a utility knife. I used craft paper or card stock. Just bought A4 packs of 10 for $2.50 from the $2 shop and taped them together.
Hoping I can make the whole boxing plate in only two sections.
Old 10-07-2014, 08:20 PM
First time with new steel used on the project. Starting with a fresh sheet of 2440x1220x4mm or 8'x4'x5/32"
First one done. You can just make out the slots where the supports for the welded in mounts will come through it.
Last one getting done with about half the sheet used plus some left overs which will be used for mounting brackets etc.
I just made the pattern for one side and will just flip half of them for the other side. Glad I took the time to make them as identical as possible.
Was surprised just how well it fitted first go! Wasn't sure how accurate my CAD, Cardboard Aided Design, would work on this. You can also see the other side plate, which is upside down, that it has be coated in weld through zinc rich primer to help against rusting inside the rails.
The templates were narrowed each side by the thickness of the flange, leaving a nice corner the fully weld closed. Fit well over the swaybar boss that had already been fully welded in. The other hole is for the rear shock mount bush that was drilled at a 8* angle the same as stock. I drilled these before putting them on the rails so no swarf would end up inside the rails.
The front half is going to be a lot harder as not perfectly flat like the rear. A total of 6 bends will have to be pressed in to follow the bends in the rail and the flange width changes.
To make the needed bends in the boxing plate to follow the frame shape, I just used a blunted brickies bolster and hit it between two sections of steel. Can use a piece of channel too.
The bends are following the frame shape quite well.
Can see in this shot how the edge of the cross member mount comes through the boxing plate where it will be welded and then ground smooth.
Also shows the only joint in the whole boxing plate. This shape increases the weld area and has the least amount of stress rises.
All plated up. Also seen is the front cradle mounts coming though and flush with the boxing plate, ready to be welded and then ground smooth.
This is part of the Grand Cherokee frame that has the rear shock mount in it. I was fortunate that the narrow section it sits in was similar to the width of the Willys frame. When I laid out the width of the Willys frame, I made sure it would run exactly along where this mount needed to be.
This is the hole for the shock mount in the Willys frame drilled at an 8* angle to match how it was in the Grand Cherokee.
Original shock mount was cut free with a hole saw and then welded in to the frame on both sides. Another piece of metal will be formed to support the other side of the shock eye so it will be in a double shear arrangement like the original setup.
Also finished welding in the other end of the swaybar mount.
Old 10-08-2014, 04:20 AM
Top job there Marcus, progressing nicely. Very neat job of boxing those rails. Also good to see you are a couple steps ahead of fabrication with pre-thinking things like Crossmember mounts and supports.
Cheers John
Old 10-08-2014, 06:15 PM
Cheers John
Thanks John. I'd rather take the extra time early on and have it go faster later when it doesn't need to be done then and take longer.
To help control distortion from the welding, I placed the two frame rails back to back with some 75x50x6mm, 3"x2"x1/4", RHS in-between. Also added additional spreader pieces where the tube was not central.
The welds were around 100mm/4" long and always balanced with the same sized weld top and bottom as well as in the same spot on other rail before moving on. This way they are pulling against each other while cooling down. I would then move forward at least a foot to a cool section of the rail and repeat. I never welded a new section that was still warm from the last weld.
I did longer welds around the area where the upper suspension mounts were welded in to balance the shrinkage it has caused on the opposite side of the rail
18 metres or 59 feet of weld later, all done.
The the weld was ground smooth. First with a 9" grinder and then followed by a 40 grit 5" flap disc to sand it just like the other side of the rail was done. More will be done later.
Was careful to remove as little of the weld as possible. That is why it has a sharper radius than the pressed corners, but rather have that than weaken it.
About 2/3rds of the frame is free of bends and wanted to keep it that way. In the end after being separated from the RHS, Rectangular Hollow Section for the non Australians, and each other, the rail had a dip of just over 1/2" from the welding. I have pressed this out slowly to bring it straight again. Applying heat opposite the weld would have fixed it also.
Got a small peak inside the end of the frame and can see good penetration all the way through without being excessive. Wiped away the white powder and was pleased to see that all the weld through primer was still intact and only a few millimetres each side of the weld had burned off.
Old 10-08-2014, 06:34 PM
Spent some time getting the rails perfectly straight again in the press after the welding on the boxing plates.
I also bought myself a 7" disc sander to make it easier to do the final sanding and get it nice and flat. Started with 16 grit and worked my way up through the grades to 80. Did it now as easier without all the brackets that will go on soon.
Back working on the rear cross member which was started some pages back. Used a holesaw to get the matching radius of the Hayman Reese receiver. You will notice it in two halves also. I spent some time fixing up the rear cross member from the other frame to box this one. You would have seen the mess it was in when I was using it as a lever to straighten the frame etc in the picture below.
The original cross member was only 2" wide and that is too narrow to use as a towbar. Needs to be 3" wide in this wall thickness. So rather than making the second cross member 1" wide to add to it, I cut 1/2" off both making them both 1.5" wide to get my 3" of total width.
The reason is it means the pull when welding will be even and will stop it turning into a banana! Also gives me two perfectly straight edges to work with.
This will actually be the side of the cross member facing outwards. I have recessed it in the thickness of the cross member so it will be flush once welded. I didn't want the receiver sticking out and it will be hidden behind the licence plate.
I am showing here how I have the centre sitting up some before welding. With the welding it will shrink and hopefully pull it down level.
All tacked up ready to weld in stages. Top followed by the bottom directly underneath it. Then jump ahead to a still cool spot to do the next bit.
Fully welded and it stayed nice a straight due to keeping it in exact halves.
Backside of the receiver welded in too. The height the receiver is set so it matches the the one on my Jeep Cherokee. That way when I tow my offroad camper, it will be nice and level still.
Upside down here, but can see how I can fit the licence plate over the hole to hide it. I will attach the plate to a piece of tubing to go into the receiver and held with the hitch pin, or fit a spring type mount where it will hinge out of the way.
Pretty happy with how the pre-set came out in the end.
Made up some mounts for the safety chains. Just copied the ones that were on the 2008 Grand Cherokee towbar, which is for sale if anyone needs one.
All done and ready for the frame assembly.
Old 10-08-2014, 06:42 PM
Not as much time to work on it lately, but thought I would throw up a little update anyway. All little bits done still add up in the long run.
Time to make up some rear coil mounts. These are the ones from the Grand Cherokee that I had unpicked from the frame. Will just use the coil locating part with the threaded hole for the bump stops.
As nearly half the mount will hang out to one side of the frame, it needs to be supported. Rather than just a couple of triangular gussets, thought I would make something similar to how it was originally supported on the donor Jeep. One was cut out and then a template made from it so a duplicate could be cut out.
I only had some 90mm/3.5" heavy walled pipe to use, but really wanted 100mm/4". So the pieces were cut out a bit bigger so they could be modified. Drew out a circle to the size I wanted and then slowly shaped the pipe on the anvil until it matched the larger 4" size.
Welded them to some left over 4mm plate for extra support
The support plates were cut out bigger by the material thickness of the coil perches all round so it could be welded right near the edge and then ground smooth. If you make both pieces the same size and weld on the edge, once ground, the weld will be lost. All the existing holes will be used as plug welds for extra strength.
All welded up and smoothed out. The back sides were sprayed with weld through primer to stop any rust between the layers.
Just sitting there at the moment and looking from the top side, gives you some idea how it will look once mounted. The covered area of the frame has already been coated as well as the back of the mount.
