Old 12-06-2017, 10:05 PM
Default Aluminum Body Repairs - Aston Martin / Lagonda
The hood of this Aston attaches to the hood hinges via hidden nut plates w/ trapped square nuts. After time and weather seize the threads enough that the square nuts rotate within their cages, it's time to fetch out the nut plates and tighten things up.
I see "flush" rivets showing but am mistrustful of the heads, so I scan the rest of the hood for further inklings:
I see plain old pop rivets.
And I see round head bucked rivets....
Hmmm, I think I am seeing mashed over heads or bucktails, instead of true flush rivets. So we drill, tentatively, looking for "on center."
No luck keeping on center because there is no true "center" with mashed over rivets. Drilling step by step until we have surely gone oversize - and the rivets are dragged bit by bit from their comfortable holes. So, I plan to use closed end flush rivets - (very strong rivets that I have replaced on F-1 cars in the past.)
Slice open a way out -- and haul out the plate. Tighten up the cage, weld the holes closed, and replace - with some spare screws used to align for the rivets re-attachment.
It all filed off nicely, so that is about it.
I surmised that the alloy was somewhere near to 3005 so I used 1100 filler, and the color was my indication of a good choice. (tig weld)
Old 12-07-2017, 04:39 AM
dwmh dwmh is offline
Thanks for showing this repair and the previous welded hood post. There doesn't look to be any sign of corrosion between the steel and ali, but I guess if it has always been in a dry area it will stay good for many more years.
David Hamer
Old 12-07-2017, 02:02 PM
Hi David,
You are very welcome.
Here is a close-up view of the hood when slit open :
I am seeing some sort of chromate-looking primer, probably laid on before hood assy. This car has been a SF Bay Area unti for long years.
Note the steel piece also has a black primer-looking coat on it.
Perhaps the combo has forestalled the inevitable - ???
Old 12-07-2017, 02:57 PM
shorty shorty is offline
Great job Kent ,have had this very same experiences with MG and Rover bonnets and door hinges.
Strangely enough Chrysler still use the caged nut system on certain parts and it does your head in ,always one bolt that gives you are hard time and of course it will be in the most inaccessible spot.
"There's a reason pain stands out in sprayPAINting"
Pat the panel beater
Old 12-08-2017, 12:46 AM
Hi Pat,
Sometimes archaic fastening systems just refuse to fade away - or improve themselves.
A stainless nut in the cage would sure improve that gizmo ....
