#311
I love the wing.
Will |
#312
Thanks Steve and Will
Mike |
#313
Just got done reading this whole post and WOW your work is amazing! Keep up the good work that this is sweet!
Michael Last edited by M.Kirby; 03-26-2019 at 12:36 PM. |
#314
All internal ribs, brackets and hardware are finished. These pieces will be installed after the panels are welded together, ship in a bottle style. Check the seam fit, of you can see it. This is not welded yet.
Mike |
#315
Nice work Mike. That is a fine looking wheel in the background.
BTW, that is serial #0001 of Imperial Wheeling Machine Model 26F.
#316
I'm impressed with the organization and the clean floor. (Roush mentality???)
Will |
#317
Kerry. I'm a proud owner of the first edition, numero uno! It's a very capable and predictable machine to use. I've had a chance to use some of the new upgrades and I really like them. It now wheels more like a cast machine but with a larger adjustment range. I've used at least a dozen wheels, including several cast machines and can say the Imperial 26f ranks very high.
Will, I hired a maid and a staging crew to setup the scene. The view from the reverse angle would show the chaos that I typically work in. But, thank you as I am proud of my many years there and the coolest programs which I was part of!
Mike Last edited by Mike Motage; 01-19-2019 at 09:56 AM. |
#318
Not everything goes as planned! I welded the leading edge seam on my wing and blow a hole. Darn it! Fixed the hole ok, but had a blob of excess filler on the inside that needed to be ground down. That makes planishing smoother.
So now I had get my die grinder inside the wing. Here's my solution, an extension for the grinder complete with valve to control rpm, since the lever had to taped.
Mike |
#319
Very clever young man!
Will |
#320
The shape of my other air extraction is finalized. I transfered the shape to a sheet of plywood that serves as the inside model. From there I bent a narrow piece of aluminum several inches longer than the perimeter of the opening. Next came the stretching of the flange corners. That sharp corner was a lot of work.
Mike Last edited by Mike Motage; 04-22-2019 at 09:48 AM. |
