Old 08-07-2018, 08:40 PM
rkolenda rkolenda is offline
We bonded a wooden box to support the area around the hood blisters.We knew that we would want to support the fiberglass before we poured any concrete to prevent the fiberglass sagging and deflecting from the weight of the concrete.In the areas that we would be clamping we added some steel reinforcements before the concrete was poured
We built another wooden form for the opposite side of the fiberglass .It was thought that we could use a medium density urethane pour foam to support the weight of the concrete form while we waited for it to cure.Our first attempt didn't work because we miscalculated (guessed) the amount of material needed and tried to mold it in two pours.
After removing the failed foam with a saw we put down a layer of plastic sheet on the fiberglass to prevent the foam from sticking to the fiberglass and reset the wooden form on fiberglass.This time we had enough material mixed to do it in one pour.This time it turned out well.This part is only used to support the weight while the mold is inverted for the concrete pour.
Mark asked about using a clamping plate.This is what we built to hold the center of the panel down .
Old 08-08-2018, 09:05 AM
Looks good, Rob. What are your plans about handling the concrete (heavy/heavier...) elements once they are poured and set?
Old 08-08-2018, 11:35 AM
Yeah this thing is not exactly portable with the weight of the concrete added in . Fortunately we have a fork lift here at the shop.
Old 08-22-2018, 05:56 AM
Sorry for the lack of updates.The old iPhone that I was using for photos died and I can't retrieve the photo's.The urethane pour foam support worked great to support the fiberglass during the concrete pour.After the concrete cured for a couple of days we used a fork lift and invert the hammer form.The temporary urethane form was discarded and it did it's job .It kept the fiberglass surface true with no distortion .I will continue the progress report with photos from my new phone.
