Old 01-06-2014, 09:26 PM
This is merely a test for placing photos and text. I have not as of yet bin successful in putting pictures and text where I want them to be.
This is a 1963 Cobra I did extensive repairs to in 2000.
This is the welding setup I used.
This is one of the fender flares that had to be replaced.
This is the wire after being unrolled and pulled out of the way. You can see the pitting that has taken place after years of racing.
Welding in the patch.
Patch after welding.
Jere
Old 01-22-2014, 12:24 AM
Bowsher21's Avatar
Bowsher21 Bowsher21 is offline
Default Pic post'n
I learned how to do it, now I just need to remember I learned how to do it.
bump 4 U
Here's my latest repaired steel body and practice at uploading pic's
Chuck
chuckshowcarphoto@sbcglobal.net
Old 02-03-2014, 10:09 AM
Bump to the top
Old 03-05-2014, 10:28 AM
Default Attempt to Upload with an iPad 3
After managing to wrestle the wife's iPad from her, this is my stab at uploading a picture taken with it. I never use an iPad......
It seems that only one photo can be uploaded at a time which means going back to repeated edits of your post to get more on. I'll give that a try after submitting this first try.
To get a picture to appear from an iPad, the simplest way I've found is this:
1. Tap the "Paper clip" symbol above the post edit window and then tap "Manage Attachments" which takes you to the "Manage Attachments" window.
2. Tap "Choose File" then select either "Take Photo or Video" / Choose Existing"
3. Once the photo is selected or taken, tap the "Upload" button on the right. The photo will be listed under "Current Attachments" as "image.jpg (size in 00.0kb)"
4. Go to the bottom and tap the "Close this window" button which will take you back to the post editing window.
5. Type the words image.jpg where you want the photo to appear and without any spaces after, tap the "Paper clip" button and then tap the "image.jpg" from the drop down box. This will insert the photo and look like this
image.jpg[ATTACH]1234*[/ATTACH]
Tap "Preview Post" to see the post and image.
Here's my try....
If this works I will try to add another image.
Sorry about the image size, the wife doesn't have any editing apps..........
N.B - Adding more images doesn't work, unfortunately it wipes out the previous image even if renamed. E.g. Image1.jpg
Phil
Last edited by Phil Minton; 03-05-2014 at 03:34 PM. Reason: Various tries to get multiple images posted from the iPad
Old 03-08-2014, 05:27 PM
Tom Walter Tom Walter is offline
Common issue with posting with iPad.
Look into tapatalk application to allow multiple photo post.
Tom
It is one of the most beautiful compensations of this life that no man can sincerely try to help another without also helping himself.
--Ralph Waldo Emerson
Old 03-08-2014, 06:56 PM
Tapatalk on the Ipad? or on the forum? We tried it some years back and there was an issue of some sort. Don't recall what.
Old 05-08-2014, 04:32 PM
Back to the top. Help us out all you new guys.
Old 05-22-2014, 05:58 AM
crazy_1_96 crazy_1_96 is offline
IMG_2442.jpgtesting my insert
Jarrad s - sponge
Old 06-04-2014, 03:26 AM
Barnsley Barnsley is offline
Default Testing
Testing
Kevin walker
Old 06-04-2014, 04:12 PM
ekdave1962's Avatar
ah and here i was attaching pic via photobucket this is much easier
Geelong victoria
Australia
