Old 09-06-2015, 07:16 PM
Originally Posted by neilb View Post
its been a while since i started this thread but here goes!
i am ready to start the outer panels now, i have had a couple of attempts at a 1/4 panel and got better with each try. i called in to see peter tommasini and ask for advise as although its not bad i know it could be better!
here is the 3rd attempt...
Attachment 34210
Attachment 34211
Attachment 34212
Attachment 34213
i had trouble with doing the top piece in one go so i cut it and tig'd it together. although its not too bad peter did give me some good advice and a few tips using the wheel.
so i left peter's on saturday and headed for the workshop to have another go, this time moving the weld joint to a more suitable place and doing the top piece in one go...
so i marked off where it would roughly join...
Attachment 34214
then had a go with a rather large piece that was a little hard to handle with my disability...
Attachment 34215
Attachment 34216
Attachment 34217
Attachment 34218
its a lot closer now but still needs a little work to get it correct, but thank you again peter
Neil you are half way there . Now look at the end of the panel (where it starts to fall down towards the rear) .... work on the bulbous shape first ,you need to block more shape in, and at the same time start doing some tuck shrinking, this procedure will make the panel shorter and closer to the right shape and fall, then help that shape by stretching the top edge above it
you might have to move the return as well .....but that it's easy done on the wheel
You are doing well keep going ,and if you think you getting in to trouble come up and see me before it's too late
Old 09-07-2015, 04:44 AM
neilb's Avatar
neilb neilb is offline
martin, richard, kent, it is a little challenging but it seems to be going well, thank you for the kind words. it will be great to see it fitted on that's for sure!
peter, I'm following your advice and its going well. thanks again
Neil
Old 09-07-2015, 05:23 AM
kiwi john kiwi john is offline
Awesome job Neil
I had a look at what you started with !!!
You are doing a fantastic job and we look forward to seeing you in December
356s are my favourite so you can bring anyyyyy bucks, patterns etc you have
cheers
john
Insanity is defined as continuing the same activities while expecting different results
Old 09-07-2015, 06:42 AM
neilb's Avatar
thanks john
looks like I'm invited woohoo lol
Neil
Old 09-08-2015, 05:37 AM
fridofreak fridofreak is offline
Hello Neil,
I LOOOOOOVE your restoration!!!!!
I'm in to the aircooled VW scene but i love the 356's and whet a craftmanswork wowww.
Keep posting i will follow these.
Thanks for your posts.
Regards Wesley
Wesley from Belgium
http://www.allmetalshaping.com/showthread.php?t=10133
Old 09-08-2015, 06:03 AM
neilb's Avatar
thank you Wesley, love your frid too. not seen any progress of it lately how is it going?
Neil
Old 09-08-2015, 06:37 AM
neilb's Avatar
got the panel a little closer today
i need to shrink this bit to get it down
so i started to make a tucking fork on the lathe as its probably quicker than waiting for one to be delivered, but I've got plenty to get on with...
Neil
Old 09-08-2015, 06:47 AM
You will be doing an HK Monaro 1/4 tomorrow Neil!
Old 09-08-2015, 07:15 AM
Attachment 34260
Attachment 34261
Attachment 34262
Attachment 34263
Neil
Put some more shape on to the bulbous right from the other end, and pull down towards the end near where the joint is going to be ,then stretch some more at the top ,( all the way) try to have the panel open a bit so you can use a flat as possible wheel ....you can always close the panel when you think you have enough shape
At this point you can start cutting SOME unwanted material off, but be careful not to cut too much!
you are doing well!!
Old 09-09-2015, 05:34 AM
Hello Neil,
Yes my frid project is set aside for a while, but now the winter is comming i whil work further.
My frid is hanging now in a rotarie, that is easy for working on and i will post some pics of it.
Thanks for asking and keep posting ;-).
Regards Wesley
Wesley from Belgium
