  #211
Old 02-04-2017, 10:39 AM
timetolook timetolook is offline
you guys never fail to amaze and inspire with the skills and work you put out..... being a total novice, this stuff is fantastic to read about and watch and learn.... Good luck with the rest of your build.
Mario
Mario
Old 02-07-2017, 12:33 AM
qkiss qkiss is offline
MetalShaper of the Month February 2020
Location: Fortuna California -- up north behind the redwood curtain
Many Thanks --- Steve -- and -- Mario.---- Much of the sheet metal is definitely what ----Jack 1957 has in his Signature Quote that states --- Set A Goal So Big That You Can't Achieve Until You Grow Into The Person That Can. This project has been an ongoing steep learning curve with much help from many of the talented people on this forum. Thank you all for your help and support. ---- Qkiss
Steve Kioukis
Sometimes your mind is stretched out of shape by a new idea never to go back to its original form.
Old 06-06-2017, 08:11 PM
Dave K. Dave K. is offline
Steve, your attention to detail is awe inspiring. Absolutely incredible work! How are you doing on the hood 'scoop'? Keep us up to date please. Thanks!
Dave
Old 06-07-2017, 10:49 AM
Thanks Dave good hearing from you. ---- Congratulations on MSOTM
I have been mounting oil filters - oil accumulator - Vacuum pump - Machining pulley drive mandrel for the front of the crank - fabricating tubing regulator bracket - radiator mounts - front end travel limiters and things that are not sheet metal shaping. Although you guys might be interested in seeing this stuff.
I really need to learn how to post pictures as attachments. One of the things that has slowed me down is the time it tacks to go through the Photo Bucket routine.
Steve Kioukis
Old 06-07-2017, 12:37 PM
Steve, mounting of components interests me. Since some of us are building whole cars, I think it still fits the forum.
Old 06-08-2017, 08:49 AM
Mike;
Just posted Tim to get the picture attachment deal figured out and then I will post more progress on the Fairlane.
Steve Kioukis
Old 06-08-2017, 08:53 AM
Steve,
Thanks for solving the problems! Your knowledge is greatly appreciated!!!
Dave
Old 06-10-2017, 11:30 AM
OK here we go with the new found skills ( posting attachments and camera size reset.)
Vacuum pump install for crank case vacuum to eliminate crank case pressure - gasket leaking and a little HP gain
Shop made crank snout mandrel for pulley mount/location.
Fuel pressure regulator mount from 1/4" 4130 tube.
Front suspension Travel limiters
Install pin in a chosen hole to limit travel.
Front end travel can now be tuned to monitor wheel standing on various track conditions.
Now a question? Are this photos OK or do they need to be made smaller?
Thank you
Steve Kioukis
Old 06-10-2017, 05:46 PM
Steve, photos are perfect, great lighting, excellent explanation. Your work is absolutely perfect! It is almost like you have done this before? I can't wait to see the car when you get it all done! Thanks for taking the time to workout tech issues! Great Job! Dave
Dave
Old 06-10-2017, 11:22 PM
Pictures look great!
I think you have found the easy button
