Old 02-28-2015, 10:48 PM
Bob Foster Bob Foster is offline
CLAY MODELS
Pro- Perhaps the only way to do manual true surface development
Pro- Easy to make a mold or FSPs from
Pro- Relatively easy to modify by adding or removing material and resculpting.
Pro- Easy to add clay to existing panels to 'develop' alternative shapes and be able to see it in full size. Refer to Mike Motage Jag project.http://allmetalshaping.com/showthread.php?t=7593a
Con-Expensive
Con-Big
Con-Heavy
Con-Easy to damage
Con-Still need to capture surface information in order to create a station buck
Con-Not really possible to pull a FSP
Con-Largely replaced by 3D solid modeling by the large automotive manufacturing companies
Recently I came across some old books that show the building of a buck where the wood stations are built a little short and metal strips are used around the perimeter. The contact area is thin enough that the slope or taper of the station edge Is not an Issue.
Neil, that appears to be a production buck. As you say it is sturdily made but there is lots of access to see the fit. The nose is solid and obviously intended to be used as a hammerform. Notice the stump, mallet, and piece of aluminum to the right of the photo.
One thing to notice on this buck is the edges of the stations. Notice how they are sloped to follow the surface.
A MAJOR issue with station bucks is that we must consider which EDGE is the contact point. Many people will run the material (plywood, MDF, ??) through a router to round over the edges so the contact line is the center of the station. If this is not considered, the spacing has to be modified in order for the curve to be fair. For instance, if you have a simple downward then upward curved surface, on the descending side from left to right, the contact is on the right hand side of the material (typically 1/2" thick). But as the curve starts to go up, the contact is on the left hand side, and at the very bottom, it is actually at the center.
I think some of the new 3D cad automatically considers this but for a backyard hack like me, it can create some really interesting challenges.
Bob Foster
Old 03-01-2015, 02:48 AM
Overkill Overkill is offline
Default Foam?
Kerry,
Over the years we've seen metal shapers use Home Depot foam insulation material and PL400 glue to create a shape they desire to make out of metal. From the canned expanding foam, to rigid sheets glued to cars and re-shaped, there have been a number of different techniques used.
Truly, I don't know if a foam shape can be considered a "buck", but it is one fairly cheap way to explore a shape. Recently a buddy of mine bought a styrofoam block, then cut and sanded to create his desired pedal car shape.
Thoughts?
Old 03-01-2015, 06:47 AM
Here's a link showing Ron Covell making a buck for a fender, it gets you started.
http://www.youtube.com/watch?v=Ktj5DWaKXYI&sns=em
Martin
Old 03-01-2015, 07:22 AM
Here is a combination buck for the front fender of my roadster.
I wasn't really happy with the design at that point. It did not have the swoopy shape I wanted. This evolved into a foam buck covered with bondo for making a true surface. My approach to that is in this post:
http://allmetalshaping.com/showpost....10&postcount=8
I believe over the course of the roadster build so far, I've used about every buck style in existence from hard eggcrate, wireform, Bert, FSP. Never used any clay though.
http://allmetalshaping.com/showthrea...highlight=deco
Old 03-01-2015, 07:29 AM
Originally Posted by Overkill View Post
Kerry,
Thoughts?
Sorry to butt in here John, but ...
Lockheed Martin sent these foam check-tools along with my contract - in 2013, so it's current tech.
I can make 6 sets of skins from each tool, which is what the job calls for - a short run of modified birds. The foam is tough enough to be machined, secured, and then handled - with respect. The first run of skins only shined up the foam surfaces.
It is very possible to buy the two-cylinder foam kit, which delivers more than a cubic yard of expanding foam. Let it harden, sculpt it, and then give it an eggshell of f-glas gelcoat. Sand that and get the metal moving.
Old 07-22-2016, 08:29 AM
Kerry, this thread should be a sticky because it contains much of the criteria for deciding on how to construct a buck that works for anyone considering such a project.
