Old 12-03-2017, 03:42 AM
neilb's Avatar
neilb neilb is offline
Default english wheel lower anvils
not sure if this is in the correct spot but i thought i'd share it with you, i have a 3d printer basically to prototype a part for my porsche project's engine cooling system. anyway i thought i would give an idea i had a go, and see if it worked.
so i drew up a lower anvil for the english wheel only to be used for tipping a radius
it needs to be smoothed out but that's easy enough to do, not sure how long it will last but it is only for tipping
Neil
Old 12-03-2017, 08:29 AM
I like it!
Old 12-03-2017, 09:09 AM
I've turned a similar profile on a lathe using baseball blanks...usually ash but any hardwood will work. They hold up well for rolling an edge. I tend to use a gokart slick rather than the steel upper.
Old 12-03-2017, 11:22 AM
Superleggera's Avatar
Questions: Which media did you use -- PLA, ABS or other? Did you utilize 100% infill? Layer height?
Interesting thought is one could engineer (and print) upper/lower wheels with different durometers as well and even do engineered infill designs for specialized wheeling applications.
Same could be done for bead roller dies perhaps?
Or an engineered type of "rubber band" to slip over the regular upper wheel?
Easy to make unique shapes, profiles, etc and the cost to do is minimal. Longevity would be an issue but most 3D printing given time involved usually can be unattended.
Thoughts from the 3D printing experts out there?
Old 12-03-2017, 01:59 PM
Default substitute produce
Of course, the 21st century has progressed and the machine will do the job itself ....... it just comes to me - we are tolded - " craft to do fight back " .
Meanwhile me, it still seems easier to process a piece of steel. But I have everything I need at my disposal. As a disposable tool, but a good idea if I have this 3D printing technology available.
Interresting idea.
Old 12-03-2017, 02:04 PM
Just Lookin Just Lookin is offline
Thumbs up 3D die prototypes - Great post.
Thank you for posting this. It is the best use of a 3D printer I have seen yet. You will surely be getting tons of questions on this as alternate (home made) die materials are always a topic here. With one photo, you have clearly demonstrated that this method/use will work and the dies will survive for long runs of tipped metal. Wow. Thanks again.
Rick in Washington, USA
Here to quietly observe and learn.
Old 12-04-2017, 12:02 AM
neilb's Avatar
I used PLA believe it or not it's quite minimal at 15% infill, 1mm outer shell.
I did do one before at 20% with a 2mm outer shell but it came unstuck from the bed. If it fails it fails, as long as it does its job it's all good.
Not sure about bead roller dies, I have drawn up some tank roll dies so ill give it a go and report back
Neil
Old 12-04-2017, 03:06 PM
Z5Roadster's Avatar
I've printed out punch and die to form Fulton Sun shield cover caps for a friend in The Catskills.
The tooling was in PLA 2mm solid fill then 0.2mm steps the punch would last possible 5 parts but the die was destroyed on 1 component material 0.012" copper/bronze nickle plated
Tom Poulter
'good to know you guys care'
https://ctrestorations.com/
