Nicely done Robert. Thanks!
Will |
#12
https://www.youtube.com/watch?v=WdtVCBCR3X4 I had some questions about weld placement, so I decided to do some samples that mimicked various body shape types to show the effects. First, we have a flat version, this would simulate the flat area at the bottom of a door skin... The second panel has more crown, such as toward the top of a quarter/door skin.... Comparing the two... Next, we have a repair piece that is joined at the beltline bead... The flat area distorts quite a bit... Normally we would planish the weld after cooling to remove this distortion, but here it was left to better compare distortion amounts.. Looking at the three samples, the flat one moves/distorts the most. The crowned panel a bit less, the beltline bead even less.. This helps to show the benefit of weld seam locations, we should select anything but the low crown/flat areas if at all possible.. The crowned areas or those with beltline bead details will help to hold any distortion in check.
#13
Thanks
This one gave me a lot of clarity and brought home what I have read and heard guys talking about but it hadn't sunk in until I was looking at the pictures.
Bob |
#14
hows the penetration ?
Ed "To Be or To Do" John Boyd |
#15
Here's the weld proud on the rear side of the beaded panel..
#16
Thanks for posting Robert .your posts are always very informative
cheers Paul
Paul |
