Old 08-28-2015, 04:54 AM
ozi jim's Avatar
ozi jim ozi jim is offline
Default Ozi 206 dino
I am back with another project, a 206 dino.
I did a lot of poking around in the aircraft forum checking out the sheet work and processes, I bought an air frame book and did some reading.
I dont know if you are ever ready but I want to have a crack at this.
I want to try to have the car look correct from the outside but underneath it will be my own.
I know the site is metal shaping but I will put the chassis up as well.
I will try not to put to much mechanical up unless someone asks.
I was given drawings of an original so I am using that heavily for measurements ect.
The original was steel tube, sheeted in alloy.
I have always wanted to build an alloy tub, riveted and bonded.
Some of the design is on the run, adding panels for strength in loaded areas.
I made 3 members to fix suspension and an engine frame to.
Size:  83.0 KBName:  P6190003.jpg
Size:  83.2 KBName:  P6250005.jpg
Old 08-28-2015, 04:59 AM
ozi jim's Avatar
Default 206
The first panel is the floor and I just built up from there.Name:  P8240009.jpg
Size:  78.1 KBName:  P8240010.jpg
The front members are placed and sheeted in.
Old 08-28-2015, 05:09 AM
ozi jim's Avatar
This panel is attached to the rear frame and riveted to the side panels.
A center board and seat structure will also add to the frame fixture.
That I do tomorrow.
The mid inner panel are installed to give a double skin, I punched and swagged the panel.
Old 08-28-2015, 05:21 AM
ozi jim's Avatar
Default 206
The floor I wanted to add some stiffeners, I looked at swagging the floor panel but this became the safest and cleanest way to do it.
I had to make some tooling to get the low profile hat.
I punched and swagged and also put joggles in for water to escape as the car has no roof and it may get rained on.
These are solid riveted.
Old 08-28-2015, 05:27 AM
ozi jim's Avatar
Default 206
Side pontoon brackets I made a jig out of 5mm alloy.
I then use a trimmer to cut the panels out.
The 2 straight folds I do in the press brake, then place on a timber jig to fold over the radius.
The fuel tank lives in the pontoon in the large holes, its a tube.
Old 08-28-2015, 05:29 AM
ozi jim's Avatar
Default 206
That all for the moment.
Jim
Old 08-28-2015, 06:11 AM
Jim this looks brilliant! I for one would like to see the whole lot
Old 08-28-2015, 06:30 AM
SATAUS SATAUS is offline
Thumbs up
Looking good Jim and ditto to what Richard (skintkarter) said.
Scott
Old 08-28-2015, 06:38 AM
I LOVE it and the rivets. Keep posting, I will be watching closely. What gauge and material are the panels? material and size of the rivets?
Old 08-28-2015, 07:00 AM
axelkloehn axelkloehn is offline
MetalShaper of the Month June '15
That looks absolutely brillant Jim! Thanks for showing!
Axel Kloehn
