Old 04-07-2020, 12:37 AM
Spraywizzard Spraywizzard is offline
Originally Posted by Gareth Davies View Post
If you’re going to spot weld the corner overlaps, why not just make it in 3 pieces and spot weld the ends in as it looks like a world of pain to try and make it in one piece? Every time I’ve tried to be clever and do a complex one piece folded job I’ve always kicked myself and wished I’d gone for the simpler option with multiple pieces. One piece jobs need to be super accurate on each fold to get them all to meet as they should do and it’s not easy on manual machines. It’s your choice but 3 pieces on a finger brake is going to be way quicker and easier.
I have thought about that, but this box is actually going to carry some pretty good weight for what it's going to be used for, I do not want any sway coming into effect after several years of use, the less welded joints the less stress.
There is a lid that will be closing up the opening too.
I just never posted the photo. And when the lid is flipped up it will screw down to the top of the box to hold a spotting scope.
Darrell
Been an Automotive Refinish Technician for 43 years .
Old 04-07-2020, 11:36 AM
Well then, since you have made a model from pattern board/chip board/poster board, can you not determine the bend requirements from bending up the pattern? Not an uncommon practical step, in the least.
Old 04-07-2020, 01:58 PM
bobadame bobadame is offline
Spot welding aluminum is very tricky to do. You probably could make it in a box and pan brake as 2 U shaped pieces with one piece being the base and 2 sides and the other piece being the top, front and back. Glue it together. Or make 2 shallow pans and glue the remaining pieces in.
Bob
Old 04-07-2020, 05:42 PM
I stand corrected. Actually you could fold up that box on a magnetic brake……. you just need a piece of steel cut to fit in between the top and the bottom so you can fold up the 2 ends. I’d try spot welding the aluminum on bits of scrap first, some aluminum doesn’t spot weld soundly. The auto body structural glue just might be a better idea. ~ John Buchtenkirch
Old 04-07-2020, 06:56 PM
The Steel box I build will be spot welded and glued
The Aluminum boxes will be pop-riveted and glued
Thanks everyone for your ideas .
Darrell
Old 04-07-2020, 07:35 PM
For aluminum box - once cut, deburred, folded up and fit, drilled and pinned -
I'd definitely-no question-100% go for "bonded structure."
Devcon makes a good line of glooos.
(Using aviation sealant "ProSeal" is good enuf for 747's ....)
Rivet wet. w/Closed end stainless rivets. Good ones! NOT McMaCaramba.
I would employ the "water break" test after cleaning and before bonding.
I suspect that dynamic loads are not a feature of your ballistic usage, but torsional, compressive, and tensile would be.
"Light and strong"
Handle?
Strap?
Old 04-08-2020, 12:01 AM
"Light and strong"
Handle?
Strap?
Both , Handle and strap will be used in the design
Darrell
