Old 09-29-2016, 02:11 AM
Futterama Futterama is offline
First quick try, not much success, need to adjust some parameters, including a harder mandrel, the hard wood I found was not that hard after all
Tolerances, shape and finish are not super important, I just need to be able to solder the two halves together.
Martin
Old 09-29-2016, 03:41 AM
what if you try to make a female die and use a tow ball, or golf ball, to form it.
Old 09-29-2016, 05:11 AM
leoitch leoitch is offline
MetalShaper of the Month April 2018
Originally Posted by Charlie Myres View Post
Good advice from Bill!
Copper can also be quenched when it is still red and remain annealed. If you use a quenching bath with, 1 part sulphuric acid, to 10 parts water, all of the black scale will be stripped off; then wash in clean water,
Cheers Charlie
hmm... remember to use full facial protection if quenching in acid. would advise quenching in water and then dunk into acid for a few minutes... much safer.
Lee.
If it itches,......you just got to scratch it!
Old 09-29-2016, 06:52 AM
AllyBill AllyBill is offline
Without making some tough tooling and stretching the material that job is going to be tricky with that steel. Can you weld? You could make it in a few small pieces then planish it over a ball bearing.
Here to learn.
William Pointer
Old 09-29-2016, 08:22 AM
mark g mark g is offline
Starting with an oversized blank will add radial resistance to the punching force, and will tend to draw the wrinkles radially from the center more.
It will then also require more force.
Mark
www.markgoodenough.com
Old 09-29-2016, 09:02 AM
So what does this mean for me? I did not fully understand what you just said
It took very little force to make the failed one, I looked at the pressure gauge, it didn't even move, so I have plenty of force available
Martin
Old 09-29-2016, 01:34 PM
Default sphere
Would it help to put equal spaced puckers in before pressing?
Bill Funk
Old 09-29-2016, 01:53 PM
Might be easier to begin with a piece of 45mm dia pipe and heat-shrink it over a tool.
Here to learn.
William Pointer
Old 09-29-2016, 02:26 PM
Did a little wood turning today, it's hard mahogni, kind of stuff used for doorsteps.
Martin
Old 09-29-2016, 03:25 PM
Hi Martin,
Sorry for not being clearer.
I'm just suggesting to start with an oversized piece of metal, so that the metal has more resistance to being pulled into the die. The metal will tend to "draw" better and with less puckering. Then trim to finished size after.
Mark
