Old 08-10-2018, 11:41 AM
Default TIG-tacking aluminum - no peek and no filler
This is for those situations where because you are holding one large panel up against another you have only one hand to tack with.
For instance, when adding a formed dash panel onto a cowl section and the weld seam will be 36 to 44 inches long (90cm to 110cm). If you can perform this little skill it will save time you will expend on a clamping fixture.
(I showed this on video/dvd back in 1995 - http://www.tinmantech.com/products/d...g-aluminum.php)
Porsche spyder #030, F2 car, new dash going in - but had to fight to keep alignment while making tack welds.
Later on I learned the Better Method from the L.A. car builders - (guys like Phil Remington, Nye Frank, Tom Hanna and others had been doing this since the 1960's) : TIG-tacking - no peek and no filler...
Set your TIG machine to AC, 60-70Amps, hi-freq start, gas flow 8.
Sharpen a clean 1/8" tung to a 45 deg angle (2% Thor - or Lanth, or Zirc or Pure - any will do just fine )
Withdraw the tung back up in the cup about .050" - 1.2 mm.
Hold the TIG torch smack dab square on the panel joint. This downward pressure is very helpful when forcing two shaped panels into alignment - with the edges touching - the panel edges must touch when tacking as the molten metal will not leap across open space because you want it to ...
Hit the pedal/trigger and wait 3 heart beats.
You have a no-peek fusion/autogenous/no-filler TIG tack.
And as many as you want.
CAVEAT: Solvent clean FIRST with 99% isopropyl ....
(WARNING: using chlorinated hydrocarbons such as brake cleaner in the presence of high frequency welding currents will create Phosgene Gas - Mustard Gas and if you breathe this it will give you a hospital visit/stay.
This is a nifty time-saving and elegant tack-welding method.
Success and joy!
Old 08-10-2018, 01:37 PM
Secant Secant is offline
That's slick!
Karl Heinz
Old 08-12-2018, 07:02 AM
Michael Henry Michael Henry is offline
MetalShaper of the Month June 2018
Thank you
Best regards. Mick
Michael Henry Sutton
Old 08-12-2018, 07:17 AM
vroom vroom is offline
Hmmm. I've tried this a number of times with smaller diameter tungstens without much luck. I would be interested to know what difference the 1/8" tungsten makes.
Tim Freeman
Old 08-12-2018, 05:34 PM
outsider347 outsider347 is offline
Neat technique T Man
Gonna give it a try
Ed
"To Be or To Do" John Boyd
Old 08-13-2018, 12:33 PM
Paul New Paul New is offline
Success and joy!
I have been using acetone for all my cleaning prior to welding is isopropyl a better choice?
Old 08-13-2018, 02:54 PM
99% Isopropyl is cheaper and just as good for the purpose - and it does not go into your liver within 20 seconds after skin contact. (So I have been told by two separate PhD research chemists, while thanking me for my recommendation ...)
Test: Wearing a painter-grade NIOSH respirator (ie: 3M 6200 + 6000 filters) wet a finger with acetone while watching the second timer tick down. When you taste it you have it.
Old 08-13-2018, 11:03 PM
Thanks for the information really appreciate it
Old 08-18-2018, 11:15 PM
To think most women have used acetone as (nail polish remover) considering they only changed to non acetone based removers in the last 10 years..........you have to wonder how their livers are going.?
Old 08-20-2018, 08:54 AM
Default TIG tacking
I can't do the "no peek" thing. I use a clear gas cup. They break easier though if you push on a burr.
Bill Funk
