Old 09-05-2018, 12:12 PM
topher5150 topher5150 is offline
Default reverse engineering sheetmetal parts
rocker boxes.jpgAs part of my training at my new job, and I do this because I must, not because I want to, the boss wants me to design and make some parts out of sheet metal. Well i have some car parts that i need help with on getting a couple of measurements. I got all of the overall dimensions but i'm having trouble trying to determine the large radius to the right of the parts. Any input would be appreciated.
kris
Old 09-05-2018, 12:20 PM
Do you want to know the radius in inches?
Old 09-05-2018, 01:51 PM
yes in inches
kris
Old 09-05-2018, 02:39 PM
Default Geometry 4 elementary school. x = r
Radius graficky..jpgGeometry 4 elementary school. x = r .
Old 09-05-2018, 03:32 PM
Here ya go.
https://www.mathopenref.com/arcradius.html
Sit a straight edge of a known length over the longest part of the radius you can and then measure the gap between straight edge and part then put the 2 figures into the formula in the link. Piece of cake.
Gareth Davies
Old 09-05-2018, 03:51 PM
Jaroslav's sketch is somewhat similar to how I would figure it.
Hard to tell from pics but it probably combination of radii, not just one. When I have to figure a specific curve and can trace an accurate duplicate pattern onto paper (like a sweeping arch in a initial 2D rendering that is simply drawn, not accurately laid out), it allows me to fold the paper pattern back on itself to see where a specific radius is present as well as its centerpoint. As long as they line up perfectly, it's the same radius. When it doesn't line up, it helps define the points where a radius changes value, so provides information about transition. Draw your chord between those endpoints and start measuring. Not scientific but quick and easy without excess math.
One of these books here has formula for determining the radius given the height of arch and distance between end points of chord from which height is measured. There's probably lots of CAD and computer ways to figure it, as well as measuring it with patterns or sweeps if you have access to them.
The above is how I do it in studio, especially for one-off stuff before making a pattern(s) to add to the collection.
Good luck.
Old 09-05-2018, 05:35 PM
Default Radius calculation
This may be easier for big arcs.
Bill Funk
Old 09-06-2018, 12:11 PM
I was to busy drawing cars in class that day
kris
Old 09-06-2018, 02:13 PM
dwmh dwmh is offline
Bill I think the denominator should be 8Xh NOT 8Xh squared.
But it is a very useful formula.
David Hamer
Old 09-06-2018, 03:18 PM
rewdco rewdco is offline
Indeed David, absolutely correct.
Jan
Jan
