Old 02-06-2015, 11:06 AM
Default Making a patch piece in heavy steel
Hi!
I got this task in my hands from a guy who working with shapes,lines and reflections every day at Volvo, a car designer, so I better do it good to please a trained eye
It is Cadillac 1955 cones made of around 3 mm steel, the pieces I made is 2.5 mm.
I shoot two videos of the work from start to finnish.
Part1
http://youtu.be/0wyhk2hR_bE
Part2
http://youtu.be/Cq19R2MGMcg
Hope you got some inspiration!
Per
www.metalmansweden.com
Old 04-15-2015, 02:38 AM
bmikkalson bmikkalson is offline
Nice, see you soon.
Ben
Old 04-15-2015, 06:39 AM
Thanks Per,
In the video, it appears your TIG is pulsing VERY, VERY fast. Did you use the pulse feature to control heat?
Old 04-15-2015, 02:38 PM
yes Kerry, then I can set the peak pretty high and keep the heat controlled with the filler rod, more filler = cooler weld but still perfect penetration
I rarely use a pedal, I use all options at my tig machines insted like the puls.
I have worked pretty hard to get rid of the pedal use, not often I just sit perfect with a bench ,more common is welding in odd positions under or inside a project and then I really like to be abel to weld without any " package"
my torch is long enough to reach everywhere in my shop, no need to bring the machine.
hope I answered your question?
Per
