Old 08-26-2018, 04:59 PM
carl 180 carl 180 is offline
Default Vintage riley wings
Hi guys a pair of wings i made i had one good wing to copy from i will try and show the pictures i have
Carl
Old 08-26-2018, 05:23 PM
Nice work Carl!
Old 08-26-2018, 05:33 PM
scotsman scotsman is offline
thats a nice looking wing you have there. thanks for sharing
William
LEARN from the mistakes of outhers, you cant live long enought to make them all yourself
Old 08-26-2018, 10:58 PM
norson norson is offline
Isn't even close to what I thought I was going to see.
Norm Henderson
Old 08-27-2018, 04:19 AM
galooph galooph is offline
Nicely done, Carl! Lovely welding too, wish I could keep the HAZ that even
Dan Smith
https://galooph.com/
Old 08-27-2018, 04:41 AM
Stretch Stretch is offline
Excellent work Carl! By sheer coincidence I'm about to make complete set also!
How did you apply the centre swage after turning the sides? Do you have a lot of clearance on you bead roller? Cheers, Matt
Matt Keene
www.air-Kraft.com
Old 08-27-2018, 04:45 AM
Looking at how you have made the sections it appears we have taken exactly the same approach. After trying to make the nearly 5 feet long Wing on my own, I concluded also that it needed to be two sections welded between the swages 👍
Here's how far I got with the first attempt before realising it really needs to be two sections if you don't have a helper to be the "tail" whilst wheeling
Matt Keene
www.air-Kraft.com
Old 08-27-2018, 05:32 AM
Nicely done there Carl.
Old 08-27-2018, 07:06 AM
Very nicely done Carl, thanks for sharing.
Old 08-27-2018, 03:33 PM
Hi matt i managed to weld the side in first then did some measureing cause the front part of the bead was bit odd on the orignal wing and i wanted it the same it just fit in bead roller was touching at some points but didnt cause any probsName:  PICT1327.jpg
Carl
