Old 08-14-2017, 01:52 AM
DanMcG DanMcG is offline
Originally Posted by dribble View Post
Hello Bart.
I'VE been following this thread and wonder as others are you going to use this to make buck or a hammer form? If it is for a buck then maybe you could cover the part with cling film and use expanding foam to give you an imprint. The resulting casting could then cut into sections allowing transfer to a positive buck.
Cheers drib (dave)
That's a great idea.
Dan
Old 08-15-2017, 02:03 PM
Hello Bart.
Cheers drib (dave)
If you were to go this route, do not use the "Great Stuff" spray can. I found out on a fiberglass plug project that it will shrink back some. I ended up using this stuff
https://www.lowes.com/pd/Sika-Polyur...l-oz/999977070
I got a couple of old jars and split the contents so I could mix up just what I needed and it cures much stiffer.
Skip Wilson
Old 08-19-2017, 05:37 AM
I have had excellent luck pulling forms from other cars by first covering the part being copied with masking tape, then coating the tape in fiberglass or bondo. After it hardens, just pull the mold off the tape. Masking tape basically has release agent built in do it won't stick to itself. Get the slickest tape you can find. I used 3m, but others may be better.
After removal of the "mold", you can reproduce the part using the same material or others.
I used to make parts this way for fiberglass cars, but no reason you couldn't use it to reproduce a buck.
Dave
Dave
Old 08-23-2017, 08:05 PM
Bart Bart is offline
These are all awesome ideas.
Thanks guys.
Yes it will be used as a buck.
Bart Risuccia
