#41
I have done some more work on the rear section.
I finished of the lamp sockets and # plate area and welded them in. I got a lot of shrinkage from the welding on this panel, it didnt suprise me with the amount put into it.
Nothing is to hard its just how much time you want to give it. Last edited by ozi jim; 02-04-2013 at 04:50 AM. |
#42
I ended up almost remaking the rear gaurd.
The duct area at the front I was not happy with the shape so I rehashed the frame buck in that area and started again. I feel much better as it looks like it should. After playing with the gaurd at the front I then found the lower rear section was just out and didnt fit on the frame by maybe 10mm. Rather than fight it I got rid of that as well. The outcome Im happy with. Between the duct and arch it is a reverse curve that runs from the duct all the way over the top. Sorry I dont know how to put an arrow in to highlight it. I played on the wheel and found in the end a 1/2 round file slapper and a small sand bag in the back worked great. I also found I had better control over the shape I was after.
Nothing is to hard its just how much time you want to give it. |
#43
I have some large parts now and I want to lock them in so on the weekend I welded the gaurd ,tail panel and deck together.
I will have to tidy up after it comes off the frame .
#44
phew! that looks good!
Brent Click |
#45
Very Very nice work! My favorite car of all time!
Terry |
#46
Looks sweet Jim!!
#47
Looks GREAT!
#48
It has been some time, I have been moving through the project.
I have learnt a lot on the job , mainly how not to do it. I got into trouble on the R/H guard because I put the body line in the wrong place (to far in). It was where the guard comes onto the rear deck and has an eyebrow curve. I moved the shape but it was stretched by this time and it took some work. I did post for help on this and it was going to get cut off but something inside me wanted to fix it. I don’t think it was the fastest way to deal with it but I have to admit I learnt a lot because I had nothing to loose. I shrunk it with the O/A I slapped it I shrunk it I beat it and finally I got it where I am happy to leave it. It was more like crash repairs, Its not perfect but this is my first time at this so it will get a little filler in some areas. I couldn’t get the wire frame out without cutting, I did have plans on saving it but not to be. #1 is the shell with the wire still in it. #2 and 3 is the welded panel.
#49
These pics are going through the fileing and bumping up on the panels.
I made about 4 slappers and purchased about 5 more hammers. I also made 3 hammers to deal with areas. I purchased a couple of round body files of Peter Tomasini ,they have also helped. I am starting to read the panels better and I know what will happen with what tool, this helps and saves time,on the rear duck tail I had a few little waves from the weld along the top edge so I was playing with a slapper instead of a shrinker and it went down so fast in on spot. I must have spent hours ,the issue of it being behind the # plate mount and very difficult to get a dolly in. I made 2 dollys and shrunk it with the O/A and recovered.
Nothing is to hard its just how much time you want to give it. Last edited by ozi jim; 04-07-2013 at 03:53 AM. |
#50
I have been taking in what I see on this site ,I have learnt rule # 1 first hand.
Clean as you go. I made the rear clamshell to fit the rear of the roof and down the sides. I did not clean as you go ,then I had the issue with the gaurd and that had an effect on the metal moving around enough to change your gaps as did cleaning the shapes on the side vents. I will redo a few small panels to fix that, the roof line is still good so I decided to finish of the panels under the rear window as this will hold the panel shape to match the roof. Before doing that I had to mount the clip on its hinges and this is done throught the rear light boxes. I ran a few options and the cleanest way was to bond angle brackets that I folded. I used the shrinker stretcher to get them to follow the body line, They are bonded in and countersunk rivets in the outer skin. The outer skins are bonded and riveted, I feel the riveted panels are in keeping with the era on this car as they were race cars and it doesn't look out of place.
Nothing is to hard its just how much time you want to give it. Last edited by ozi jim; 04-07-2013 at 03:13 AM. |
