  #501
Old 03-29-2020, 10:49 AM
The factory had four mounts close to the front of the body, so I figured I should do the same since the fenders bolt on there.
I started with some 18 ga brake formed channels. I zip cut them to size, drilled drain and mount holes. I used some large rings of tubes as anti crush sleeves.
The mount bolt goes thru a 1/4" thick stainless disc that is welded into a round tube, welded to the floor.
Old 03-29-2020, 10:59 AM
Originally Posted by MP&C View Post
Safety first!
Thanks. Here's some more.
Exploding transmissions make me nervous so I added a 1/8" steel band. This is done the same way as the other floor brace/mount locations.
I mentioned exploding trannys to my daughter and she insisted on another one as she likes to ride shotgun when I go for a cruise.
Started with a template or two......
The 4th pic shows the cardboard template. I then used that to transfer to the 1/16" thick wood keep on hand. Clamped the 1/16" wood to the 11 ga steel sheet and use the power nibbler to cut around the perimeter. I then pounded it into shape over open vise jaws using a piece of cutting board plastic to spread the blows. I could have drove to work to use the roller, but I didn't feel like washing my hands ten times by the time the trip was done. It worked out about the same time all in.
Old 03-29-2020, 11:05 AM
I hit with weld thru primer where required. Welded everything in and cleaned up.
Old 03-29-2020, 11:40 AM
MP&C's Avatar
MP&C MP&C is online now
You’ve been awful busy today!
Nice detailed work !! Thanks for sharing the progress!
Old 03-29-2020, 01:53 PM
dwmh dwmh is offline
Super job. Keep up the good work.
David Hamer
Old 03-29-2020, 05:58 PM
Superb work again. I use the open vise jaw method too but will have to try the plastic board as well.
Old 03-31-2020, 07:10 AM
drivejunk's Avatar
Nice!
Matt
Old 03-31-2020, 09:40 AM
racer-john's Avatar
Default 41 Chrysler New Yorker Coupe
Nice to see your work, pugsy.
John S. E
Old 08-16-2020, 05:42 PM
Thanks Guys.
Old 08-16-2020, 05:53 PM
The last bits of cowl done.
