Old 06-16-2019, 07:24 AM
neilb's Avatar
neilb neilb is offline
Default cheap good way to cut tube + plate
just been watching a video about electric tube benders and came across this video, https://www.youtube.com/watch?v=LfdkwoxQXA8 really interesting and a really good idea
just thought i would share it, @ 5.5 million views i'm sure some on here must have seen it...
Neil
Old 06-16-2019, 08:05 AM
I've been using a 7" diamond grit metal blade like this https://www.homedepot.com/p/RIDGID-7...-204202535-_-N on a dedicated circular saw for quite a while and like it very much. The steel cutoff wheel is cleaner (no dust), lasts well if you don't overheat it and doesn't change dimension so it produces more consistent & accurate cuts. It's simple to use an edge guide as normal for very good long straight cuts and not too difficult to avoid scratching the base metal.
Old 12-19-2019, 11:55 PM
Can you run this metal blade dry, or do you need to use coolant? I've seen them but never tried one.
