  #501
Old 06-21-2018, 07:05 PM
Had a few hours and decided to rough out the decklid skin. Interesting piece that was harder than I though it would be. The contour is different top to bottom quite a bit.
Wheel work in the center and some shrinking along the edge. More at the top than the bottom. It easily passes Kent White's 'two finger' test. That is, with very little pressure it lays down as it should.
I'll shift gears and get the inner structure finished and the hinges working. In order to get the gaps set correctly at 1/8", I'll need a 3/16 gap to the opening and I'll need a rigid location in order to do that. Then I'll do the final shaping on the skin and start the wrap.
Old 06-21-2018, 07:13 PM
rkolenda rkolenda is offline
Hey Kerry , good to see you going at it again.A 1/8 inch. gap in bare metal will close up quite a bit once you add primer and paint. You may want to open it up a bit.Bob.
Old 06-21-2018, 08:49 PM
that never crossed my mind. What do you suggest Bob? 3/16?
Old 06-23-2018, 08:43 AM
rookie rookie is offline
Glad to see that you have been, putting time in on the Roadster Kerry you are making good progress! Its been interesting watching the car come alive over the years. Be well!
Phil
Old 06-23-2018, 10:07 AM
Yes Kerry,3/16 the should do it.
Old 06-24-2018, 09:24 PM
A little more progress.
I wanted to get the hinges squared away to verify they would actually work with the decklid without further modification.
I tacked a reinforcing piece to the outer perimeter frame. I CAREFULLY measured and drilled the holes in the tulip panel then positioned the frame where I wanted and marked the holes. Once drilled, the hinges fit perfectly with spacers as planned although the vertical alignment is still off because the spacers are not correct but that won't be an issue. Better yet, the frame opens and closes fine. No binding, wobble, or side to side movement and it swings up and down just fine. Now I can trim it for the required gap of 1/4" all around. After that, I'll finish shaping the decklid and install it on the frame. 1/4" gap plus the .063 wrap of the decklid material will yield a 3/16 gap before primer and paint.
But first, I needed to do something about the quality of my opening. I failed miserably at tipping a nice tight 90...miserably! Because of the fabrication I did on the weatherstrip flange, it's hard to get to the area to slap it into a tighter 90. So I cheated and ran a TIG bead around the 90 and will file it to a 1/16 radius.
I've ordered a new fuel pump which didn't come in today. I really need to get the car outside and make sure I'm happy with the profiles.
Last week, I read through this entire 12 year saga. I have to admit it's been quite the journey and while I've made most every possible mistake at least once (and too often multiple times), I've also learned a great deal.
While reading, I got to the part a few pages back where we were discussing the side vents. One reason I want to get it outside is so I can make some temporary panels with the various vent designs and take some photos. I'm not sure I'll change anything but I won't know until I know.
Old 07-07-2018, 06:38 PM
No shaping but a huge step forward. The engine has not been started in 4 years or so. Yesterday, I drained about 4 gallons of bad gas, replaced the fuel pump, and picked up a kit for the carb (500cfm Edelbrock). Once I got the carb apart I saw that I didn't need the kit and will be taking it back. There was varnish EVERYWHERE and the screens on the float needle seat were plugged completely. That probably explains why it wouldn't run except when I primed it.
All better now. Fires right up and idles great. Now to make a path so I can back it out of the shop for some perspective. Also, the lift room needs a LOT of TLC so I need to spend a few days cleaning it up and cleaning it out. It's been embarassing to post photos that showed all the crap in the back ground.
Better days ahead.
Old 07-07-2018, 11:32 PM
MetalShaper of the Month August 2018
No shaping but a huge step forward. The engine has been started in 4 years or so. Yesterday, I drained about 4 gallons of bad gas, replaced the fuel pump, and picked up a kit for the carb (500cfm Edelbrock). Once I got the carb apart I saw that I didn't need the kit and will be taking it back. There was varnish EVERYWHERE and the screens on the float needle seat were plugged completely. That probably explains why it wouldn't run except when I primed it.
Better days ahead.
Hi,
We use aviation gas 100LL (Low Lead) for engines that sit a lot as the fuel doesn't go bad. Most airport will fill a five gallon container if you tell them what it is for.
Very nice project.
Bill
Bill Tromblay
"Remember, the camel was a horse, designed by a committee" My mentor and friend, Gil Zietz Micro Metric Machine.
Old 07-08-2018, 05:05 AM
Glad to hear you got your engine running again.
Old 07-18-2018, 10:46 AM
Got it outside for some perspective shots. Also installed the wheel centers. Don't forget there will be a panel below the door to connect the front and rear fender bottoms.
I took some shots at different elevations. Still thinking about the side vents. Will definitely do something different.
And for perspective, here are the glamor shots from the generation 1 back end that I cut off.
Back to the current
Once I finish up organizing in the lift room, I'll get back on the decklid. I'm going to, once again, attempt to keep the shop de-cluttered so I can back it out from time to time.
She runs but not well. I think I need to spend more time on tuning it. I also want to redo the clutch slave cylinder. With the original headers, there was not room for a traditional push slave so I went with a pull cylinder. It never was as smooth as I wanted it to be. Now that I have cast iron split headers, I have room to go back to a standard push cylinder. I think the problem is the cylinder itself but as long as I'm changing it, I'd rather go back to a more standard setup.
