  #141
Old 10-11-2018, 12:20 AM
pistol pistol is offline
Im with ScooterRo .This thread needs an R rating .this metal working porn
cheers paul
Paul
Old 10-11-2018, 09:22 PM
pplace's Avatar
pplace pplace is offline
Good stuff there.
Like those unions. Where does one buy those?
Check out Juliano's Hot Rod Parts. Pro-Clamp Stainless Steel Exhaust Coupling
cheers paul
That made me laugh! Thanks! It's been a bit slow going lately visually....but trust me I'm still working, planning, figuring, etc.
Currently I've designed some body mounts for the chassis and am in the process of fabricating them. I've got a lot of things to take care of, but I'm starting to seriously think and plan for my floor, inner structure, wheel wells, firewall, etc. Anxiously awaiting when I can get "visually" productive again.
Dane
Old 10-12-2018, 04:54 AM
Thanks.....
Old 10-13-2018, 06:54 AM
Onorius Onorius is offline
MetalShaper of the Month Dec. 2018
Wow, very nice work and project. Thanks for posting.
Onorius
Old 10-16-2018, 06:45 PM
pplace's Avatar
Nothing too major to update. Like I mentioned last time, I'm trying to button up some smaller tasks (still important, just not visual and "exciting" I foresee myself getting pretty serious on figuring out some floor structure in my near future though!
For the time being here's a batch of photos showing a body mount standoff I designed and the steps for fabricating them (I built 6 matching ones)
CNC Plasma Tables
I've always wanted a CNC plasma table but it's just never been a necessity (nice to have...but there are always other things / tools we needed more seriously) However, I do believe I've talked my mother (front office $$$) That it's getting to a point that my time and labor can be spent in better ways than drilling and cutting out smallish brackets by hand.
I've got my welding supply company looking at some options (though they may be a bit higher than what we'd like to spend) Looking for a decent one, not cheap, but not industrial and outrageous in price. For what I do I honestly think a 2'x2' would cover 95% of what I'd plan to cut.....though having one may expand my horizons and I'll find out I'd like bigger?!?! For space reasons in our shop I don't think I could manage / fit anything bigger than a 4' x 4' comfortably.
I do my cad designs on a laptop most often and would probably prefer just a USB type port / display on a cutting table rather than a full computer out in our shop atmosphere. For what we do 1/8", 3/16" and 1/4" plate is the norm....doesn't get heavier than that.
Does anyone possibly have any input on a table that is affordable, yet useable (I know you typically get what you pay for) There will be times I'm using this table a lot during a build, then it may sit for months not getting used. So a table that can stand up to 24/7 use isn't necessary. We are kind of hoping thinking there is something available in the $3000-$4000 range (not including a plasma cutter)
Thanks
A short while back I figured up all the specs for getting a driveshaft built. The customer had a local contact where he's from build a nice aluminum driveshaft.
It really looks at home tucked between the mufflers. Everything worked out as planned.
A view from the side with the suspension "air out" showing how deep the driveshaft tunnel will need to be eventually.
Laying out and cutting all the pieces for the 6 body mounts. Slow and tedious (see question at top of post in regards to CNC plasma tables)
All the individual pieces cut out and ready to assemble into a mount.
I made a "jig" fixture to help assemble each body mount.
The top is turned down so the hole in the top pad plate centers on the jig and it's temporary bolted together......
Align and locate one of the side plates and weld the flat area up to the start of the radius......
Heat and bend / form the radius around the jig (the jig was turned to the correct radius needed)…….
Attach the second side and repeat the process. Once done all the joints are fully welded up. Unbolt the jig and slip it out from the body mount.
Here I'm holding a mount roughly in position
You can see how I worked around the fuel and brake lines.
Dane
Old 10-17-2018, 12:03 AM
jmcglynn jmcglynn is offline
nice work. What are the rubber mounts from? I need to build body mounts - I was thinking I'd machine something out of delrin, but ready-made is a better idea.
Old 10-17-2018, 10:33 AM
Default Plasma
I could never justify the space for a CNC plasma cutter. So I put a fiberglass(nonconductive) extension pole off the end of the CNC mill table. With a hand plasma torch attached, I can cut small parts. 20"x12" I also use this scheme to hot wire cut foam. Even put Oxy torch on once to make cool oxide patterns on copper sheet.
Bill Funk
Old 10-17-2018, 12:14 PM
pplace's Avatar
Energy Suspension brand. You can get either universal mounts or vehicle specific. They are a polyurethane.
No CNC mill here either!ha I agree with being able to justify having one for cost and space reasons....though many hours of my labor are being wasted where it could be spent more productively and more accurately as well. Right now my options are looking a bit more (nearly double) than what we’d “like” to spend. We’ll see how it plays out the more research I do.
Dane
Old 10-17-2018, 01:38 PM
CNC Plasma Tables
Thanks
Dane, if you follow the link below, you’ll see what we have available in the UK at that size and budget so it’s entirely possible to get what you require within budget. I’m not sure how costly it would be to import from the UK (if Donald allows it [sorry for the non-metal shaping comment]) but it might be a possibility.
https://www.wellyweld.com/products/S...ble-73650.aspx
Gareth Davies
Old 10-17-2018, 03:05 PM
You could also just send the drawing to a company that does laser/waterjet cutting.
