Old 04-02-2017, 03:06 PM
Default More thanks to sponsors of the redneck Roundup.
I was having trouble with the following picture, so I started a new post.
Craig Peterson with Dagger tools made the trip to the Redneck Roundup for the second year and was also Very generous to those in attendance. In addition to his generosity, he a very knowledgeable gentleman and freely shared his experiences with us here at the Roundup.
We also had great door prizes from MANY other kind folks like Jimmy Matthews, Stan Fulton, Dan Shady, Mike Yurko, Cotton Eubanks, Dal Larue, Cary Culpepper and probably some one that missed. Here is a link to other items that Dagger Tools has available. http://www.daggertools.com/44.html
A special thanks to Jeff Fournier who was also VERY generous with a number of prizes, but especially a set of very shiny T-dollies, a pair of hammer forming DVD's and other items. Here is a link to other items that Jeff offers. http://www.fournierenterprises.com/6m3.html
Another note of Appreciation to Ben and his Mechammer. Not only was his machine is constant use (I failed to get a good photo -Sorry, Ben), but Ben provided several of his very popular small, easy, useable radius gauges. Here is a link to Ben's Mechammer. http://www.mechammer.com/
Old 04-02-2017, 03:57 PM
Default Many bucks in use at the Redneck Roundup
We had several bucks available for use and made a couple of new ones as well.
Jim and I at the final assembly of the wood radiator buck that will be used to start the body fabrication the conclusion of the chassis welding.
Wood radiator buck with out the original grill shell installed.
Bob Baisden's concrete buck made for use on his Ford Cobra build.
Modifications made to the original radiator shell buck
More modifications made to the original radiator shell buck
These bucks were made for Cotton Eubanks to use in building aluminum panels to build a scale model land Speed record belly tanker.
This buck is for the canopy area of Cottons belly tanker model.
This recently completed buck is for building a Model A fender
Left rear for the Bugatti build.
Old 04-02-2017, 04:20 PM
Default Tool Exchange pictures from RR4
The tool exchange was good again this year. I like doing this. I received the wooden slapper right in front of me, made by A.C, Clint Button II (Cliffrod)
There were (12) tools available at the table this year. We had 38 attendees so that works out to 1/3rd of the attendees brought a tool. THANKS guys!
Jake 'Tiny' Ladd (Memphisrain) won a Dan Shady slapper and a set of corking' tools
Dan Shady got a pair of metal slappers made by Steve Hamilton.
Steve Hamilton got a shaping hammer made by Jake Ladd.
Jeff Newton picks out set of handmade vixen file handle made by Jimmy Matthews.
Clint Button (Cliffrod) chooses a hand powered bead roller from Dan Pate.
Andrew Slater picks up the slick tool that Mike Yurko made for steadying your hand when TIG welding.
Pat Brubaker (Patman) chooses a tool that Tom Olson made to hold a sharpie when creating a radius.
Tom Olson picks up the set of edge tipping tools that I provided.
Not shown are Jimmy Matthews that got the slick tucking tool made by Pat Brubaker (Patman), and Mike Yurko chose the TIG torch 'spot welder' that was made by Jeff Newton.
Old 04-02-2017, 04:24 PM
Default Bugatti build parts
Assorted items were made for Jim Hery's Bugatti build.
These are the fixtures that will be used to fabricate the chassis for the T57 Bugatti.
They were layed out by Barry Duckworth, drilled by Dale Larue and welded by John Trautnau.
Dale Larue acquired and cut the holes in mill for the inner tube on the long Bugatti muffler.
Some pieces had to be 'borrowed' from the original tank.
This is the left side, outside end panel for the gas tank showing the location for the gas filler inlet tube.
Jim Hery is viewing an assortment of sheet metal parts for the Bugatti radiator shell that was made by Mark Quells from Tennessee.
A prototype rolled section for the gas tank made by Robert Robinson from Georgia.
This is the radiator mount fixture for the build table. John Trautnau is using the radiator crank bracket support as a hole locator.
Old 04-02-2017, 05:30 PM
The tool exchange is always good! I love the idea of making and exchanging handcrafted tools. I have two from Steve Hamilton, one from Bob Kolenda, one from Jeff Newton and the latest one from Mike Yurko. All have a story and a history, and are treasured items.
The door prizes are also treasured items. This year I won a very nice wood bossing mallet to match it's larger cousin from Craig at Dagger Tools, an extremely nice set of supple deerskin TIG welding gloves from Steve Hamilton at Hamilton Classics, and a pair of Snap-On socks from Dan Shady at Vintage Automotive. . .which for the record, are THE most comfortable socks I've ever worn (I should have never doubted you Dan Pate!).
Seriously folks, if you are a member of this site, do yourself a favor and make the time for an event. You will learn a ton of things, and make life-long friends. I usually use all my vacation time to make these events. You will be there 12-16 hours per day, just trying to absorb as much information as possible.
If you want someone to do your project for you, this is not the place. But, if you need advice, everyone is more than willing to help you. These events are for people willing to learn, and those who have a passion for metalshaping. Think of them as "mini-apprenticeships". . .there is an amazing amount of talent any any given event. You will be a better shaper for attending one.
I've been working on my YSR50 fairing at almost every event over the years, and every year it gets better due to advice from fellow shapers. I started it as a complex shape to challenge myself. It is kind of like my calibration tool. If I have to do something new, I can always look at the fairing and think about how I got there due to some key piece of knowledge. There are too many to name, but a few come to mind: Kerry Pinkerton helping me sort out FSP's and wheeling, Dan Pate discussing shape vs. arrangement and planishing, Pat Brubaker showing me how to think outside the box on weird arrangement issues, Per stressing the importance of getting the shape and arrangement correct before welding, Steve Hamilton helping me with any number of issues I was having over the years, and Will and Jeff Newton for getting the brain juices flowing on the any number of crazy ideas we've had.
At this event, Jim Hery was taking a break from the Bugatti project, and jumped right in helping me tackle the final hurdle for my fairing. . .the metal finishing. Working on a small 5" x 5" section, I learned more about how to pick, file, and finish in 20-30 minutes than I could have in months of working it without a watchful eye. I will always treasure this knowledge, and it is the same with all the help I've had over the years. These skilled craftsman have just jumped in to help give advice. In most instances, I didn't even ask.
If you are inspired to learn this craft, you owe a great debt of gratitude to those who post on this site, and to those who take the time to post and put on these great events.
To those who take the time out of their lives and close up their businesses to host events, Bravo Zulu.
Andrew Slater
HANGAR 18 FABRICATION
Old 04-03-2017, 10:04 AM
memphisrain memphisrain is offline
One of the highlights was getting to hear Will's speedster fire!
https://youtu.be/EW7F4nZkmhE
Big Jake
"I've never met someone with so much tenacity in all my life." - RockHillWill
@madscientistind
Old 04-03-2017, 11:55 AM
Andrew let the disease continue. At 50.00 bucks a week for life you can fill your drawers full of socks
Dan Pate
Old 04-03-2017, 12:17 PM
Gando Gando is offline
The best things about "the round up" are all the comments mentioned so far as well as a few I wish to add. The fellowship of like minded people of all skill levels and a culture of learning are what brings me back every year! The knowledge, techniques and friendships I've gained are immeasurable!
Will and Peggy are most gracious hosts and embodie true southern hospitality at its finest! It's always a sad trip home when it's over because it is such an awesome experience but I immediately start looking forward to the next one!
Thank you Will, Peggy and all you rednecks in metalshaping land!
"Gando"
David Gandy
Concord, N.c.
Old 04-05-2017, 11:05 PM
mr.c's Avatar
mr.c mr.c is offline
I had a great time at Pat's class and the following redneck roundup. I learned a lot at Pat's class including a clever use of the TuckPuck with an arbor press. Silent shaping.
It was good to be with my old redneck friends and meet some new ones.
I received a Pullmax operation DVD from Kent White as a door prize. I watched it this evening. It is very good information and much appreciated. Thank you, Kent.
Carey Culpepper
TuckPuck® Metal Shaping Tools
www.tuckpuck.com
Old 04-06-2017, 12:23 AM
Wish I could been with you all this year too, but no chance to " slip" away this time.
Very glad to see all fun, tricky and wow work going on!
Thanks for sharing all photos so I can " be with you" this way.
Take care!
Per
www.metalmansweden.com
