  #71
Old 05-29-2018, 08:20 PM
Bill the car is coming along nicely
Old 06-09-2018, 07:35 AM
vroom vroom is offline
Really nice work Bill. Thanks for the detailed how-to. I always get a bang out of the guys that say our predecessors just bent these tubes over their knees. The voice of experience ? NOT!
Tim Freeman
Old 06-10-2018, 06:21 AM
Way cool stuff! I am following with great interest.
Old 06-10-2018, 10:31 AM
Just thinking out loud, I wonder if tube bending of this sort would be easy to accomplish if a length of wire cable (wire rope) were inserted through the tube before bending. I know the cable has its own limit as to how tight a radius it can tolerate. This may act as a flexible mandrel within the tube. Experimenting with finding the correct combo may get the answer. Find out how the cable diameter should relate to the tube inner diameter will be key. Also lubrication and ease of extraction and method are to be discovered.
Old 06-11-2018, 02:54 PM
Good idea I hope you let us know how it works out. A really tightly wrapped cable might be best.
Bill
Looking at your construction again I wonder if the plan is to wrap the panels around the tubes at the trunk opening or to create some sort of drain rail?
Tim Freeman
Old 06-11-2018, 05:43 PM
mastuart mastuart is offline
My guess is if its tight enough to help it keep from kinking it will be a bear to get out.
Mark
Old 06-11-2018, 06:57 PM
Another bending option would be filling the tube with sand (must be dry!!!) and heating the area to be bent. Poor mans mandrel bender, works well when doing exhaust tubing, should work well for this.
Old 06-12-2018, 12:19 AM
I've used the sand fill before. There are a few essential steps. First, cap one end, then fill the tube all the way. Place it on a vibrating plate so the sand settles in, fill it again until you can just place a cork at the other end, then go bend.
Other approach is various formulas of low melting metal.
See one at: http://www.csalloys.com/cerro-alloys...ng-filler.html
Marc
Old 06-12-2018, 05:57 AM
Did the same thing when I was making roll cages. Works fantastic,
Old 10-21-2018, 09:39 AM
pistol pistol is offline
Ive been travelling around Italy for the last 4 weeks and end up in modena. I went to the Enzo Ferrari museum there and thought of this project while I was there. I was wondering how is was going? .Is there any updates?
cheers Paul
Paul
