Old 03-18-2013, 05:10 PM
Flavourless Flavourless is offline
Default 26g CR steel sheet
I was curious if anyone has had any luck finding any 26g sheet? I am having the hardest time finding it anywhere in the states and it is something that I desperatly need to proceed on with this aircraft restoration I am working on.
Ryan
Ryan
RS Designs - Metal fabrication and upholstery
Old 03-18-2013, 07:15 PM
I saw something that will help , A shop somewhere in the us will reroll sheets to your guage . I am sorry but i threw the magazine the other day . it was in Fabricator mag .
James
Old 03-18-2013, 07:34 PM
Steel or aluminum? You mention gauge which is normally steel but then you also mentioned it was for an airplane??
Old 03-19-2013, 08:49 AM
cameron cameron is offline
How much is is needed? If only a small quantity, you might consider removing the very thin zinc coating from Satincoat steel (also goes by other names). Or maybe can be used as is.
Should be easily available in 26g.
Dave Cameron
Old 03-20-2013, 09:03 AM
found it .... www.admiralsteel.com
james
