  #51
Old 03-18-2018, 10:31 PM
onya onya is offline
There are a few Panels in my Shed that look similar to that mashed up one.
Leigh,
Old 03-19-2018, 03:51 AM
Good on you for getting back to it and learning from the first attempt. Only way to learn.
Old 10-23-2018, 09:12 AM
It's been a while since I've added to this, so here are a few significant pieces I've made that got me swearing a lot.
As you can see, this slam panel requires replacement as the lacy metal is bit thin to fill with mig. The complete cross member is available, but it's just the top section that's knackered.
This is the tool I made from aluminium
And this what I got
So after tipping flanges & trimming, I'm getting closer
So a trial fit with the outer panel it's ready to weld up
And all tidied up. like new
Martin
Old 10-23-2018, 09:48 AM
Nice............
Old 10-23-2018, 03:57 PM
carl 180 carl 180 is offline
Nice job Martin looks factory.
Carl
Old 10-23-2018, 04:32 PM
Martin - you're hired!
Old 10-23-2018, 11:59 PM
Top job Martin!
Old 10-24-2018, 03:17 AM
Nicely done.
Old 10-24-2018, 03:21 AM
Thanks Pugsy, Carl, Kent & Richard, high praise indeed, much appreciated,
This rather tired looking piece of metal has had its day...
This is a technical piece for me, I started where you should finish on this part, by putting the flange in first, my thinking was the complex shape would not twist out of shape if I did this first...
So I took a pattern & cut this, then put a 15mm flange on it..
Then after a lot of shrinking, shaping on the stake, cuts & bruises etc, I got to this stage with both halves tacked together..
Then tig welded them up..
Then after some metal finishing & fettling, it seems to fit
Then welded up, nice & shiney
Martin
Old 10-24-2018, 04:28 AM
Now, that piece is over the top.
Excellent job of it.
