Old 02-08-2019, 04:39 PM
JSark61 JSark61 is offline
Default Chassis Fabrication
I have a question about building a set of frame rails for a future build of my dream car. I want to build a Roadster that has both European 30's racecar/ indy car and American Hot Rod based on a 400 Pontiac engine and using 1932 Pontiac as a vehicle basis
My question is how would one go about building the side rails? I'm thinking of starting with a c channel the desired height and length then cutting my profile then weld the contoured areas to create the rail side profile . I also would like to mimic a Bugatti type 59 frame with lightening holes and a boxed inner rail
any ideas/additions are welcome as I am in the planning stage
Thanks in advance
"If its a piece of metal, I want to make it look different"
Jerry Sarkozi
Old 02-09-2019, 02:24 PM
drivejunk's Avatar
All I heard was blah blah blah Pontiac because I like Pontiacs and Pontiac V8s.
I think most folks would look at prefab deuce rails first, or start with tubing. If you want that Swiss cheese look bad enough but plan to use a boxed rail... maybe design it bearing in mind that the piece with all the holes would be more cosmetic than structural. Heres my disclaimer: I am not a chassis fabricator.
Now... what is your dream car to be used for? Track and wins or trailer and trophies, or will you strap in a wife and newborn and dash about cities and interstates surrounded by two ton SUVs constantly playing double the speed limit? Intended usage is relevant, thats all.
Matt
Old 02-09-2019, 04:14 PM
Maybe Jim's Bugatti threads, like this frame build thread, might provide some inspiration...
http://www.allmetalshaping.com/showthread.php?t=17990
Old 02-09-2019, 04:48 PM
Thanks for the input , yes I am a Pontiac guy always have been, tooold for newborns strapped to the dash. it’s intended purpose is occasional use maybe the Oakland roadster show , I’m not big on following the 32 Ford frame . The frame I build would be fully boxed and the holes would have inserts.
Jerry Sarkozi
Old 02-09-2019, 04:49 PM
Great lead ! Thank you!
Jerry Sarkozi
Old 02-09-2019, 04:51 PM
Just wondering about the desire for the 'swiss cheese' side rails. Do you have a way of keeping out road dust, dirt, gravel and ice and snow from highway driving?
"inserts" ????
I really like the rendering.
Old 02-09-2019, 05:13 PM
"inserts" ????
Mostly want it for asthetics , to have a departure from the norm !
The insert would go between the inner/outer dimple die hole to add strength
Not really concerned with dirt gravel and snow especially, it will be under a roadster , fair weather only !
Jerry Sarkozi
Old 02-09-2019, 08:39 PM
geelhoed geelhoed is offline
Meet Hosts
I would build the rails street rod style (4pcs) because of all the curvature. I would waterjet the pcs . Maybe cut the round holes in 2 pcs. My current build was done in round tube(indy style) Your rendering shows a str 8 motor not a V/8?
Andy
Old 02-10-2019, 03:53 AM
cvairwerks cvairwerks is offline
Jerry: Probably the best way to do the rails is from flat stock. You need to work out the hole/tube assembly process first though.
Looking at the variety of sizes on your drawing, a number of methods could be used, but a couple of areas would be really difficult. If you've got machining capability, it might be the best to simply machine up a tube with the ends flared and simply weld and grind flush to the rail faces. For consistency, you leave some alignment tabs on rails when they were cut, stack and tack weld them and then bore your holes thru all four at one time. Align and weld in all the tubes, then weld on the top and bottom plates to complete the boxes.
Food for thought.
Craig
Old 02-10-2019, 07:31 AM
Andy
The rendering is a Bugatti chassis that’s why the straight 8 lol my rendering is still pretty much in my head. I figured due to the profile ultimately I’d end up doing the 4 piece rail. I had considered Indy tube style also but I like the exposed frame for some reason
Thanks!
Jerry Sarkozi
