Old 11-11-2017, 05:47 AM
Paul-S Paul-S is offline
MetalShaper of the Month July, 2016, November 2017, July 2023
Default MG F magna radiator shell
Hi
I have been spending some time last summer in making a polyester copy as a buck for an MG brass radiator shell.
I want to gain experience in working with brass and like the challenge .
Finally started with making the paterns and first panels.
Here some pictures!
Happy with it so far.
Greetings Paul
Greetings Paul
Old 11-11-2017, 07:38 AM
I take it you are going to be making more than one of these?
Looks like a good way to make repeatable shells. Are you able to do some shaping on the buck as well for fine adjustments?
Old 11-11-2017, 07:44 AM
Very nice !!
Old 11-11-2017, 07:53 AM
Hi Marcus
Well lets see what my end product will look like!
If it's good enough wich offcourse is my goal I would like to make a few of them
Thanks Peter
Greeting Paul
Greetings Paul
Old 11-11-2017, 10:43 AM
Looks very good.
Is the polyester buck solid polyester or formed over a wood/metal core? Approximately how much polyester did it require- the entire 20kg, more or less?
Old 11-11-2017, 04:49 PM
Nice job on the buck, looking forward to seeing progress on this one.
Gareth Davies
Old 11-12-2017, 12:51 PM
Hi Cliffrod
The buck is solid polyester mixed with fiber as filler add.
About how much I've used.
Less then the 20 kg becouse of the fiber add.
I estimate about 17 kg
Gareth thank you!
Paul
Greetings Paul
Old 12-17-2017, 08:42 AM
Hi Shapers
Yesterday finally had some time left do make a little progress on my shell.
Finished the second side and made a start on the bottom.
Here some pictures.
Greetings Paul
Greetings Paul
Old 12-17-2017, 05:43 PM
Metal man bryan Metal man bryan is offline
Hi are you gas welding or tig are you using parent metal as filler or something else or is it fused with no filler thanks bryan
Bryan
Old 12-18-2017, 12:59 PM
Hi Bryan
Im gonna use tig on this with a filler rod.
Can be done with both.
Greetings Paul
Greetings Paul
