Old 02-25-2018, 12:02 PM
Default spot welding aluminum ?
I spot welded some scrap .025 thick 2024-T3 aluminum I had into a box to hold file folders. The spot welds seem okay but I had some trouble with the steel sheet I was using sticking to the aluminum. Is there any trick to avoid the sticking ? Thanks ~ John Buchtenkirch
Old 02-25-2018, 12:40 PM
bobadame bobadame is offline
Maybe a bit of oil.
Bob
Old 02-25-2018, 03:14 PM
I had heard that stainless steel was used, don’t know about sticking.
I did try it a number of years ago don’t remember it sticking.
Old 02-25-2018, 03:37 PM
I think thin stainless would do the trick. From memory, Jimmy Hervatin posted a short video on his Instagram showing just that.
Gareth Davies
Old 02-25-2018, 04:50 PM
Sorry guys, I just tried the SS on both of my spot welders and it’s still sticking just the same as steel. Thanks anyway, it was worth a try. ~ John Buchtenkirch
Old 02-25-2018, 05:01 PM
Maybe reduce the time, or current?
Gareth Davies
Old 02-25-2018, 05:07 PM
https://instagram.com/p/BVsOsoDjL1Q/
Gareth Davies
Old 02-25-2018, 05:45 PM
Originally Posted by Gareth Davies View Post
Okay, in the video you can see he had to pry off the SS scrap pieces which is basically what I had to do. Not a big deal but it can markup softer aluminum. For whatever it’s worth I only used the steel and also tried SS on one side and it welded fine. Also the copper spot tip never stuck to the aluminum but I don’t think copper scrap would raise the resistance enough for the aluminum spot welding process to work. ~ John Buchtenkirch
Old 02-26-2018, 06:14 AM
neilb's Avatar
neilb neilb is offline
all the aluminium i have spot welded it was using steel between the tips, try using thin copper between the steel and aluminium
Neil
Old 02-26-2018, 11:49 AM
BRAVO………. that worked perfectly ! You only really need to put the copper then steel on one side (to raise the resistance) and it seems to work just fine. THANKS Neil ~ John Buchtenkirch
