  #1131
Old 02-15-2019, 06:57 PM
Wow, Jack- The more you post, the more you teach... What a great thread! Thank you very much.
Very cool.
Old 02-15-2019, 08:30 PM
Nice work Jack, Looks great.
Are you going to attach the tube as full round or are you going to cut it in half and attach fitting clips now you have the right bend.
Old 02-15-2019, 09:33 PM
John, I'm going to leave the full round tubes in tact. I'm working on the mounting brackets and there will also be 4 tabs along the upper edge with rubber bushed bolts (Motorcycle battery box mounting bolts) to hold the upper edge in place but not too rigid. It's difficult to see in these pics but the bolts are screwed into the tabs, then into the rear body panel. The mounting brackets are bolted to the frame rails.
Old 02-16-2019, 08:28 AM
Mario428 Mario428 is offline
Learn something from every post you write. Thank you
Mario VanWiechen
Old 02-17-2019, 10:46 AM
Kelly was successful with casting the parking lamps. He did those and the grills first. In the first picture, you can see that the sprues and gates are attached and the patterns are covered with a thin coat of plaster. After that they are put in a container with loose sand and vibrated, then poured.
Name:  1 Mudded Up.jpg
End results were very good. I was really worried about getting this done in one attempt. Very relieved to see the finished parts came out great.
Next, the tail light housings. Same routine. This is where knowing what you're doing comes into play. Proper sizing and positioning of the sprues is critical in ensuring that the molten aluminum gets to every space of the mold before it starts cooling so you don't get any folds or dry spots.
He may not be able to get to these right away since he brings the foundry equipment outside to do the melting and pouring. He said they are expecting snow. We'll see what happens. I'm very pleased with the results so far.
Name:  7 Mudded TL.jpg
Here are a couple links to some of his previous pours:
http://forums.thehomefoundry.org/ind...water-neck.90/
http://forums.thehomefoundry.org/ind...on-system.119/
http://forums.thehomefoundry.org/ind...ifold-lid.366/
http://forums.thehomefoundry.org/ind...l-carrier.543/
http://forums.thehomefoundry.org/ind...nder-head.268/
http://forums.thehomefoundry.org/ind...test-2017.142/
http://forums.thehomefoundry.org/ind...m-patterns.14/
Old 02-17-2019, 12:35 PM
Jack,
Ditto-Kudos
Couldn't access any of the links to added to the end of your post!
Bummer!
Marc
Old 02-17-2019, 06:19 PM
Marc, the links work for me but I think that's because I'm a member. Go to the home foundry and sign up. It's easy and they don't spam you.
Old 02-17-2019, 06:57 PM
Bob Bob is offline
Kelly is having great results with lost foam casting, I follow his efforts on his forum and on youtube. Learned a bunch just from that.
Your parts turned out nice.
Bob
Old 02-17-2019, 07:58 PM
kcoffield kcoffield is offline
Default Links
Jack, I get page not found error at the links.
Best,
Kelly
Kelly Coffield
www.inlinecarb.com - My Old Carburetor Habit
http://www.alloyavenue.com/vb/showth...nace-Build-Log - My Home Foundry Furnace Build
Old 02-17-2019, 08:04 PM
.....This is where knowing what you're doing comes into play.
I've been mistaken for someone who knows what he's doing once before. .
Snowed all day today Jack.....no casting. -Will have a go at the tail light buckets next weekend.
Best,
Kelly
Kelly Coffield
