Old 03-29-2018, 07:01 AM
Iain Iain is offline
Default Stainless trim
Whats the best grade of stainless for cold forming trim I would have thought 304 or 304L.
Any suggestions?
Reality must take precedence over public relations because nature cannot be fooled....
Old 03-29-2018, 09:11 AM
Default Forming Stainless
IF you are going to weld it, 304L has low carbon and less likely to crack.
Bill Funk
Old 03-29-2018, 03:24 PM
Not possitive but i think you might find alot is made out of 400 series mirror polish
Old 03-30-2018, 02:19 AM
longyard longyard is offline
Which of the 400 series is the best choice? As I've researched 400 series, I keep running to the phrase "...not as corrosion resistant..."
I need to make a grille surround piece for a Ferrari Dino. The original part is mirror finish stainless, about .015.
Any help on sources for the stainless stock would be much appreciated.
Bill Longyard
Winston-Salem, NC
Old 03-30-2018, 02:35 AM
Default 430 Stainless for Trim?
430 Series seems to be good for stainless trim. Thoughts?
https://www.onlinemetals.com/merchan...=826&top_cat=1
Bill Longyard
Winston-Salem, NC
Old 03-30-2018, 05:08 AM
Bill
I have no clue which it is I get skelotens from lazer shop , I do not think they make many mirror polish alloys
Old 03-30-2018, 06:42 AM
Thanks folks. I'll see if i can get hold of 304L and 400 series if possible.
Old 03-30-2018, 09:15 AM
bobadame bobadame is offline
I worked for a factory that made stainless steel machinery for the fast food industry. Once while doing inventory in one of the warehouses I remember seeing 400 series panels which were covered with a very light rusty haze. Nothing serious, normally you could easily remove the rust with a scotchbrite pad so long as you're ok with changing the original finish. For that reason I've always stayed away from 400 series.
Bob
Old 03-30-2018, 04:41 PM
greenfield greenfield is offline
430 SS mirror (mill finish is available and if doing a lot of forming/joining might be a better way to go and then polish) is what you want. it is used on most OEM car trims.
When they were actual metal.
Matt Mig
Old 03-30-2018, 06:16 PM
Thanks Matt!
Bill Longyard
Winston-Salem, NC
