Old 02-13-2014, 06:07 PM
rcv4 rcv4 is offline
Default styrofoam buck
Has anyone worked with extruded polystyrene foam to make a pattern/buck i have a few projects i would like to try it on,what is the best way to shape it and work with it,glueing finishing etc,thanks.
Chad
Old 02-13-2014, 06:37 PM
Just Just is offline
yes, i worked with an acetat resistant foamsheet, 35kg each m3 so it is strong enough to make a buck, and soft enough to work with hand, and resistand enough to can use aceton, polyester-resin, and all other boddy material
if you look at " sika-block-material", you can find a lot about this modell-block-material, and if you dont make a full material buck, it is not so expensive
i make prototype-car bumpers and some motocycle fuel tanks with this modell-block´s, easy to work, easy to repair, easy to shape, easy to make a mould with this
http://necumer.com/index.php/en/
Just Ernst
Old 02-13-2014, 06:51 PM
Go to post #8 of the Art Deco Roadster thread and read the next couple pages.
http://allmetalshaping.com/showthrea...highlight=Deco
Old 02-13-2014, 07:16 PM
thanks guys.
Chad
Old 02-14-2014, 08:22 AM
mark g mark g is offline
Metal Shaper of the Month, April 2011, December 2012, May 2016
Chad,
Here's another thread to check.
http://www.allmetalshaping.com/showt...3273#post63273
Mark
www.markgoodenough.com
Old 02-14-2014, 04:33 PM
Originally Posted by mark g View Post
Chad,
thanks for that mark,i enjoyed your thread cheers.
Chad
