Old 06-25-2017, 03:01 AM
elavir elavir is offline
MetalShaper of the Month May '17
Leaks happen in clean-room environments, with excellent back purge, and cameras inside the tanks, as I learned from the guys who build Kenworth and Peterbilt tanks. Perfect appearing TIG welds, inside and out - leak - because of weld density issues. Welds are sliced open along their lengths, and voila! - porosity inside the weld, invisible from outside.
It's a problem that the most expensive tig machines are only just now starting to overcome.
Thanks for the explanation Kent, just now I am making a tank and tried to weld with and without flux . In both cases the penetration was good but as you described this can be misleading. I am going to flux the remaining welds just to be sure.
Cheers Richard.
Old 06-25-2017, 03:17 AM
Originally Posted by Rick Mullin View Post
Seldom do I have porosity when welding with 1100 wire on 1100 or 3003 sheet metal. 1100 was not the correct wire for the alloy of the tanks I have built so I was using the harder wire as Kent has mentioned (4043 or 5356).
Rick
Hi Rick, I am using 1050 aluminum for the tank and for the correct "color match" I am using strips from the same sheet as the tank. In combination with back fluxing I guess It would be OK. I can't find it but I thought to remember that welding with 4043 could crack sometimes.
Cheers Richard.
Old 06-25-2017, 08:36 AM
Cheers Richard.
Richard,
4043 is a Silicon-bearing rod that has a low solidus (low re-solidifying temperature). 4043 was designed for welding castings. It is a hard, brittle filler that cracks when it is hammered / wheeled.
Old 06-25-2017, 08:37 AM
Cheers Richard.
Thanks Richard. Good luck and please post your results with the back-up flux.
Old 06-26-2017, 07:40 AM
The fittings that I machine are 6061 so that is where I am using the 4043. Most tank are made from 5052 so I am using 5356 wire. Generally no hammering or crushing of the welds. On a few tanks that I made for D types, I used 3003 (butt welded) which did require some planishing and the wire I used was 1100 with great success. The bulk of the alloy tanks that I am making require edge welding of a flanged seam thus no planishing required. I am anxious to try fluxing. Kent- What do you suggest to thoroughly clean the flux form the inside of the tank (particularly the edge flange joints)? Flux is always my worry. I have seen far too many coachbuilt cars with flux corrosion that leaves me a bit nervous.
Rick
Rick
Old 06-26-2017, 03:07 PM
Hi Kent, I'm not sure if I can make pictures of the remaining welds because they are inside the the last sheet to close the tank. Maybe through the filler neck.
The pictures below are the ones I made with and without the flux( bottom weld is with and top weld without flux)
I had difficulties to see the puddle that was fluxed because of the orange flair but then again it was probably too thick.
Cheers Richard
Old 06-27-2017, 12:12 AM
Attachment 42229
Attachment 42230
Cheers Richard
Richard,
It looks to me as though the flux is helping your welds. Sorry about the flare - it is a problem for electric welding that I have been working on.
Old 06-27-2017, 12:25 AM
Rick
Hi Rick,
Flux has been an issue with welded aluminum cars since 1910, to a greater or lesser degree. Less flux into a weld means less flux to clean up.
I have seen pre-war Alfa bodies with only slight residues left where they could not be cleaned on the back side - and only slight corrosion left, after 50 years. But, on the other hand .... I have seen serious backside corrosion from excessive flux ...... Maybe better to use a little less of the good flux rather than a lot of the avgerage flux?
So, I flux only the rod when welding clean and fresh stock.
And I rinse first with hot water, and then I rinse with 25% phosphoric - whatever available brand, MFR, Ospho, Dairyland rinse, etc.
I don't try to rinse the phos. completely clean because it adds protection against corrosion.
For joining 6061 to 5052 the 5356 is recommended by the AWS filler charts. 4043 is a second choice, or third.
Many thousands of aviation fuel tanks were gas welded from 1920 onwards. Rinsing with hot water was S.O.P. in the factories.
