Old 09-17-2017, 06:48 AM
Bart Bart is offline
I'm in a slow process of making a roof skin also for another car.
I use angle aluminium or angle steel is fine.
I make a length the same width as the roof or length of the roof, then stretch the edge of the angle aluminium to bend it to the same crown as the roof.
Then trace the bend/crown of the angle to MDF board. That can make your buck
Bart Risuccia
Old 09-17-2017, 07:23 AM
X2
This is an excellent way to make profiles.
Old 09-17-2017, 09:38 AM
Dave K. Dave K. is offline
Bart, I am trying to visualize what you described, is there any chance you have a picture of this process? I am really interested in seeing how it is completed. I have done this method and would like to learn it! Thanks!
Dave
Old 09-17-2017, 06:21 PM
Do you have a basic Lancaster Shriner / stretcher that you can take a piece sheet metal 1 1/2 " wide by the length the opening as well as some the width of opening. Make several and form an angle similar to piece of angle iron. Now with you Lancaster stretch the one side of the angle so that it follows the radius length wise and width to make sort of a buck to then shape your skin to
Dan Pate
Old 09-17-2017, 07:30 PM
maverick5582's Avatar
maverick5582 maverick5582 is offline
Default Roof Skin
Originally Posted by route56wingnut View Post
Do you have a basic Lancaster Shriner / stretcher that you can take a piece sheet metal 1 1/2 " wide by the length the opening as well as some the width of opening. Make several and form an angle similar to piece of angle iron. Now6 with you Lancaster stretch the one side of the angle so that it follows the radius length wise and width to make sort of a buck to then shape your skin to
Yes, I have a Shrinker/Stretcher. I understand your idea. Would you make the roof insert about 1/2" oversize and final trim it? I am trying to decide if it would be better to make it oversize and use Clecos to hold it in place to trim it or use my deep throat vise grips to hold it in place. I am going to Tig weld it and I need the fit to be as close as possible. On small pieces I have always use the belt sander to sand the edges to final dimension. It makes the cuts straighter. I am switching over to .040 tungsten and .035 ER70S-6 wire for this job. I am hoping to be able to tack it then weld 1" at a time then skip 2" and make another 1" weld.
Thanks for the input.
John a.k.a. Mav
Old 09-18-2017, 05:01 AM
Always oversize and trim afterwards.
Old 09-18-2017, 12:13 PM
Always make your panel oversized so that you are allowing yourself the ability to work the panel further out. Any functions done towards the Edge are difficult to control as there is no resistance at the edge so it will over shrink or stretch at that point
Dan Pate
Old 09-18-2017, 12:45 PM
Default Roof fitting
So how are you cutting the donor roof? Are you laying it on the Anglia roof and scribing a line from the edge of the Anglia roof inside and adding a 1/2" or so to the line or what?
I am having a hard time understanding how you can cut the donor roof from above and get the two cuts to line up perfectly for a Tig weld.
John a.k.a. Mav
Old 09-18-2017, 01:49 PM
I should have paid more attention I thought you were rolling a panel nor just getting from another. But I would take templates established from your car and head to the salvage yard and check those against a donor
Dan Pate
Old 09-18-2017, 02:08 PM
Default Roof Panel
I am going this week to pick up a mini cooper roof. I have been told this is the best donor roof available. Based upon the advice I have been given this is the least difficult job considering my experience level at this time.
John a.k.a. Mav
