  #51
Old 11-25-2017, 03:49 AM
Originally Posted by blue62 View Post
We need a write up on how you do all that fine work and still keep your shop so nice and tidy
Ha ha, thanks mate.
Originally Posted by bobadame View Post
Excellent work Marcus. Thank you for showing the process, your work is inspiring.
Thank you Bob.
Originally Posted by Steve Hamilton View Post
I like the proportions of your cab much better than his. The bottom of your windshield being lower really is a great improvement!
Glad to hear it Steve. Hope to one day be parked next to each other and see the differences then. Maybe a stock one as well.
Old 11-27-2017, 11:17 PM
Glad to share.
I got some 13mm-1/2" bar stock and cut down to the depth I wanted to tip the flange. Just used a 1mm cutoff disc and taped where I wanted to stop, 14mm-9/16".
Makes a good way to scribe a bending line to follow later too.
Slide the bar all the way in and bend down bit by bit. Actually found you could hold the same angle down and just knock the bar along and it would bend it down as you went along. Tape gives a good visual to make sure you are all the way in.
Corners are done the same way.
Once a couple of times around I switched to using my flanging pliers to speed things up along the straighter lengths. Bar was still used in the corners and kept at the same level of bend.
Probably took 6-7 times bending a little more getting the 90* bend.
As you see it now only the bar and the flanging pliers have been used.
Was pretty close already but some fine tuning to even any highs or lows. With this dolly behind the flange, I hammered on dolly, stretching the metal, near the bend if I wanted to raise it. Hammered on dolly only at the bottom of the flange if I wanted to lower it some.
One nice and stiff roof panel ready for an insert later on that will be removeable.
The insert can bolt through the newly made flanges with T type rubber seal in between.
You have made a fine job of that roof opening - I'd not have guessed you would go the bender bar route with that but you caught all of the details, one by one. Really great to see how even and true you got the flanges and the edges of the opening. Very tricky to get it right, with a lot of patience and sticking to the plan. And the window surrounds - nice when offcuts can go right back into the stew.
Bravo, Marcus !! Very clean and even project !!
(I might know a chap needing a top chop on an old FB wagon ... I think I'll send him your way ... )
Old 11-28-2017, 04:50 AM
Many thanks Kent. Learned a lot from what you have posted over the years.
Old 12-13-2017, 06:38 PM
Excellent work as usual Marcus.
Thanks.
Old 12-14-2017, 02:57 AM
Thanks.
Thanks mate.
Old 12-14-2017, 05:08 AM
Ivar Ivar is offline
Marcus,
thanks for posting all pictures. It's so handy to see this, a lott of learning from this for my own project! Keep up the good work!
Ivar Pieper
Old 12-15-2017, 03:00 AM
Originally Posted by Ivar View Post
Marcus,
Glad it helped some Ivar.
