Old 09-02-2018, 07:48 PM
Default Heat shrinking
Hello all, I am shaping a small panel that has a flange, the panel is distorted and I believe the flange needs to be shrunk. I don't want to mark up the flange, so I thought I would use a propane torch and an infra red temp. gun. My question is what is the lowest temperature that you can use and still get shrinking action.
Thanx,
Tom
Old 09-03-2018, 01:43 PM
Thanx,
Tom
I'd say that you ignore the gun and apply the warm with your air-propain flame until the metal is blue/purple - about the minimum heat for this, assuming your metal is steel.
When hot then pat down with flat face on flat dolly/back up bar - hard wood is fine.
Old 09-04-2018, 06:11 PM
Kent, thanx for the response, I was just trying to do the least amount of trauma to this panel and exercise the maximun control. My first attempt, I use a heat gun and turned the flange a medium brown color. It was too slow and uneven, my next attempt I used a shrinking disc, the flange heated up to a blue color (500+ degrees?), the flange shrunk and most of the distortion was removed from the panel.
Old 09-05-2018, 11:57 AM
Attachment 48667
Attachment 48668
Hi Tom,
Lowest heat for shrinking sheet of thickness <.063, that I have successfully tested for, is no color but when the sheet has swelled to its max.
You can see the various heat colors -I hope - in this chart, below. The purp-blue is one of my favorite low-temp colors, for hot shrinks on mild steel. (Helps a lot of your color-perception is good ... )
Low temp color chart.pdf
Hope this shows up ...
Old 10-05-2018, 07:02 AM
Shows up fine, thanks.
Dave
