Old 07-23-2014, 09:57 AM
Nutsonmercs Nutsonmercs is offline
Default Paint stripper recommendations UK
Hi,
Looking for recommendations for paint stripper to take off automotive paint located in the UK. I've tried Nitromors but it seems to have very little effect other than softening the paint. I put clingfilm over it to stop it drying out but that just ended up melting I sprayed it with water to stop it drying but it still doesn't improve. Are there specific ones one steel and aluminium. I have both to strip. At £51 for 4 litres the Nitromors wasn't cheap so hoping for some recommendations before I waste more money
Regards,
Peter.
Old 07-23-2014, 11:59 AM
Hi Peter,
I've just just these on aluminium, works good, ebay no. 121165488412 or this 360981011663, I would say however having just stripped a shell, that giving it 10-20 mins to work, then scrapping while still soft is what I found to be the quickest method, waiting for it to blister is slower. I used a blunt !" chisel, I didn't gouge the ali, I would also D/A sand the paint first with 40g, this speeds things up too.
Martin
Old 07-23-2014, 02:44 PM
flakey flakey is offline
Starchem paint stripper, evil stuff. 1 coat, leave for 20 mins give it a scrape, next coat nice and thick cover it in plastic sheeting for a couple of hours, the sheeting stops the evaporation of all the toxic goodies, we sometimes leave them overnight with a sheet on.
Fintan Ellis
http://www.fhellis.com/
Old 07-23-2014, 05:19 PM
Looks like Starchem is the winner, thanks both for recommendation
Regards,
Peter.
Old 03-26-2016, 12:22 PM
retropower retropower is offline
Yea starchem for large panels.
It's actually possible to get hold of dichlomethane stripper for industrial use, I have been known to use it....
Nasty stuff but works very well indeed
Sure chemicals in Tamworth http://www.surechemicals.co.uk/indus...aint-strippers
Nat Seviour, owner/director at Retropower Ltd, general metalbasher!
Old 03-28-2016, 04:58 AM
What wrong with a heat gun and scraper.....a lot cleaner,
Just not sure what would be worse, Chemicals or heat fumes.
Old 03-28-2016, 12:54 PM
AllyBill AllyBill is offline
http://www.chemetall.com/Special/Pro...rs/all/all/all
Best in the business, these guys.
Here to learn.
William Pointer
